Will an "A" or "T" spring fit on a 35 or 36 diff with orignal wishbones?
Discussion in 'The Hokey Ass Message Board' started by oldrelics, Jan 14, 2011.
  1. oldrelics
    oldrelics
    from Calgary
    Will an "A" or "T" spring fit on the rear of a 35 or 36 diff with the original 35-36 wishbones?
  2. thunderbirdesq
    thunderbirdesq
  3. oldrelics
    oldrelics
    from Calgary
    Does anybody know if either the A or T spring will lower it more than the original 35-36 spring?
  4. alchemy
    alchemy
    Have you looked at those springs? An A or T spring will make the car lots higher (if used in the original crossmember). The only reason to put an A or T spring into a car like a 36 is to clear a quickchange. And the corresponding A crossmember is used with it.
  5. need louvers ?
    need louvers ?
    An A or T spring won't lower the car with the stock cross member. If you need to do this because of a quick change, I would recomend you use an A spring and cross member rather than T. It's a 1/4" wider like the origianl 35 36 spring. The combo tegether still shouldn't lower the car, thats what reversed eyes and de arching is for.
  6. oldrelics
    oldrelics
    from Calgary
    I do have the corresponding X-mems for both, I was just wondering from a baseline setting, also didn't know if the A or T spring was more stretched out to mount on the bones perches( which would lower the car as well)...
