Technical Why do so many ‘32 fords run ‘40 rims?
Discussion in 'Traditional Hot Rods' started by 65standard, Dec 28, 2020.
  1. LOL steelies coming out of my ears. I got this instant image in my head.
    I got an idea that the '40s wheels were/are an upgrade. The thing to remember is that until we came along cutting edge was the real deal if you were a hot rodder.
    hotrodjack33 and 31hotrodguy like this.
  2. 5window
    5window
    Well, if you have an outer metal circle connected by spokes to a central hub, then I'll grant you "rim" vs "wheel". But, if the entire outer rim, disc and hub are one piece/welded together then I would argue there is no difference between this "rim" and "wheel". Semantics.
    hotrodjack33 likes this.
  3. hotrodjack33
    hotrodjack33
    For those who can't accept the term "rim" for the whole metal part of an automobile wheel...well, you technically can't call that metal part a "wheel" either.
    Wheel
    NOUN;
    A circular object that revolves on an axle and is fixed below a vehicle or other object to give a mechanical advantage and enable it to move easily over the ground.
    In general, it would be the sum of ALL the parts (including a tire) that actually meets the definition of a wheel.
    firstinsteele likes this.
  4. hotrodjack33
    hotrodjack33
    Hey Ben, Just having some fun. Please don't take me too seriously;)
    But, while I'm at it...probably a more accurate term for a rim/wheel would be a "tire adapter" as it's ONLY real purpose is to allow a soft, flexible rubber tire to be firmly mounted to a stable axle/hub. I doubt the term "tire adapter" will catch on...so we have to call it something...:p
    31hotrodguy and 65standard like this.
  5. Dedsoto
    Dedsoto
    from Australia
    1. Aussie HAMBers
    Wire's will crack on a 40 brake drum, better brakes made the swap nearly mandatory. These days you can buy support rings of the shelf to either fit your wires or slip onto the 40 drums.
    31hotrodguy likes this.
  6. 65standard
    65standard
    1. COE's (Cab Over Engine)
    I’m using ‘41 brakes and ‘35 wires. Can you explain better why the wires will break with my combo.
  7. 31Apickup
    31Apickup
    On the 35 & earlier cars there are nubs on the drums that support the wire wheels when bolted down. On the later hubs without the nubs, the wheels aren’t fully supported and will crack, you need the support rings.
    fatabone and 31hotrodguy like this.
  8. Mr48chev
    I'd say that between them they hit it pretty close. You didn't need to fiddle with the spacers to use wires on the 40 hubs if you ran 40 wheels. Plus for a lot of guys it was probably "More Modern" Remember, there were no "traditional" hot rods then, just hot rods.
    joel, 5window, clem and 3 others like this.
  9. -Brent-
    -Brent-
    He's talking about using wire wheel rings to support the wheel centers on the juice brakes so they have a flat surface to sit against.
    They look like this:
    Stogy, 31hotrodguy and Tman like this.
  10. I use them on wires always!
    Stogy and 31hotrodguy like this.
  11. 'cause it was a step up from grandpa's wire wheels, soon to be followed with OHV mills.
  12. 65standard
    65standard
    Are these hub centric rings so the weight is supported on the hub instead of the lugs?
  13. If you look at the wheels, the stamping only goes around the outer side of the lug hole. On a 35 drum there is a corresponding raised section on the inside of the lug, thus supporting the wheel all around the lug hole when you tighten the nuts down.
    On later brakes, without support lumps, you deform the wheel on one side of the lug hole because it is no longer supported. This leads to cracking etc. The rings reinstate this support.
    31hotrodguy and 38fordpickup like this.
  14. 65standard
    65standard
    Thanks everyone. I understand completely now about the need for support rings.
  15. Good wire wheels are getting hard to find. The 16" wire wheel was one year only, 1935 (not counting the handful of very early '36s that left the factory on '35 wire wheels). The '32 wheels were 18" and '33-'34 were 17" I have a pair of '33-'34 wheels that are too rusty to use on a car (both have rust penetration all the way through on the rim). I use one to roll up my air hose on and one to roll up electrical cords on. One has a '33 cap on it and one has a '34 cap. If you can find a set of '35 wheels, it's a matter of preference. I think a Model A looks good on '35 wheels, prefer '40-'48 wheels with baby moons or a Ford cap ('42 is my favorite) on '32-'35. On wires or solids, I prefer powder coating to paint.
    olscrounger, 31hotrodguy and clem like this.
  16. A Boner
    A Boner
    40 rims= HOT ROD!
    35,34,33,32 wires= antique looking hot rod
    31hotrodguy and -Brent- like this.
  17. 65standard
    65standard
    2B4B31D5-91D3-487C-9BC3-A26B2F748136.jpeg I will gladly use ‘40 wheels as long as I can use these V8 hubcaps. Bob Drake says these are 1940 caps? If these fit, I will go with the 1940 wheels.
  18. alchemy
    alchemy
    Bob Drake knows better than that. Those aren't 1940 caps. Model "40" doesn't mean 1940, it means Ford's designation of a 1933-34.
    None of these wheels are hub centric. That concept wasn't even thought of for decades.
    olscrounger, Baron, RICH B and 2 others like this.
  19. 31Apickup
    31Apickup
    Those caps as noted are for model 40. 33-34 wire wheels. Look up caps for a 40 Ford standard, they have the V8 logo on them.
    olscrounger likes this.
  20. Baron
    Baron
    Because they look so darn good.
  21. Illustrious Hector
    Illustrious Hector
    Dedsoto just did, think physics, greater clamping force on a weaker wheel. the same reason drum brakes have one set of linings longer than the other.
  22. 65standard
    65standard
    I picked up five ‘40-‘48 Ford wheels and five ‘36-‘39 wide 5 wheels. The wheels came with 6.00-16 tires, but those aren’t going to work. I’m thinking 7.50s on rear and 4.50s or 5.00s on the front. Plan on using the ‘40 wheels unless I come across the wide five hubs and drums to use the ‘36-‘39 rims. 46539299-1C1F-4EC7-A4AC-1BEA085FE27D.jpeg FA5545F1-7871-4D1B-8790-F0A2985A79DC.jpeg
    31hotrodguy and Baron like this.
  23. clem
    clem
    you make a valid point, - something I also had noticed looking at old hot rod magazines, - yet no one today seems to follow that particular traditional trend in their quest to be traditional...........
  24. JJK
    JJK
    What's your tire and wheel sizing?
    Baron likes this.
  25. sloppy jalopies
    sloppy jalopies
    '32s ran 18" tires, one year run... not many size options...
    '35 to '48 car and '35 to '57 trucks ran 16" tires...
    the other makes ran similar sizes to year... many more 16" options...
    getting a good used 18" was tough but finding a 16" tire was much easier because of the multi year run...
  26. Tickety Boo
    Tickety Boo
    from Wisconsin
    Hot rod upgrade "no mag wheels yet for triditional" plus set your car apart from the others. :cool:
    Dad told me on his Black 39 Chevy he painted the rims red, also he had a long whip antenna that mounted on the back bumper that was long enough to tie down on the front bumper. Was this a trend in the 40s ?
    My uncle totaled it out while Dad was in the Philippines 1944-45
  27. ssffnomad
    ssffnomad
    Adam401 :
    Front- Ford 16”x4”
    Rear. - Zephyr 16”x5”
    A Boner, adam401 and Tickety Boo like this.
  28. dirt car
    dirt car
    from nebraska
    The simple fact of the whole discussion is back in the day just as this very day we tend to run what we have at hand, what we're able to find, & often times even if not our first choice we can develop a preference for it.
  29. Baron
    Baron
    16 inch wheels / 1940 front, 48 rear. 5.50 x 16 on 16 x 4's, 7.50 x 16,s on 16 x 4.5's.
  30. brady1929
    brady1929
    The reason: Because they look so damn good.
    A Boner, Baron and Tickety Boo like this.
