Specifically a 320ci to 350ci V8 motor. How street friendly is it. What type of cam are you using. How many carbs (cfm)? Are you running the outside or inside carbs as the primaries? I have found a bit of info in older posts, but not quite this detailed. Any help would be appreciated. I'm building a 327 AMC w/ th400 switch pitch trans. Any multiple carb setup would have to be a log type manifold. Thanks
I'm not running one, but if I do, I may buy one of these "build your own" kits from this guy: http://www.lakeheaders.com/UFabIntakes.html ~Jason
