Hot Rods Who builds the Ansen pedal assy.
Discussion in 'The Hokey Ass Message Board' started by JimSibley, Dec 30, 2019.
  1. JimSibley
    JimSibley
    im an idiot, I need another Ansen style clutch pedal assy, and I dont remember where I got my other one. And help would be great.
  2. 51box
    51box
    from MA
    Rjays Speed Shop makes a setup and he’s an alliance vendor
    Nailhead Jason likes this.
  3. brigrat
    brigrat
    from Wa.St.
    I won't mention names but one guy makes a beautiful set up BUT lacks proper brake pedal ratio, prepare to lengthen pedal or pedals............................................................
  4. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    I like R-Jays as he has lengthened his pedals I think 3 inches and they work really good. I have them in my deuce pu.
  5. 5window
    5window
    If you won't mention names, how on Earth is your post at all helpful to someone not already familiar with the issue, ie the OP and me???
  6. Fordors
    Fordors
    @krylon32 is correct, RJays makes his pedals with a correct ratio now. In fact I posted in a thread started by @daddy_o’s _diner
    a couple years ago when the issue of ratios came up and at that time RJays (sorry, I don’t recall his screen name) said that he would provide revised pedals for anyone that wanted them. You can’t ask for more than that.
    3kross, Don Nagel and 5window like this.
  7. rudestude
    rudestude
    I have had this set of pedals for 35+ years and have never used them , I have to make a new shaft for it, the original one got misplaced years ago.
    I don't know who made them, haven't found any markings on them.
    I might put them in my Studebaker that I'm building at this time. 1577725286250~2.jpeg 1577725504863~2.jpeg
    Sent from my SM-T387V using The H.A.M.B. mobile app
    catdad49 likes this.
  8. brigrat
    brigrat
    from Wa.St.
    "If you won't mention names, how on Earth is your post at all helpful to someone not already familiar with the issue, ie the OP and me???"
    Now you were warned to ask questions first not just buy it cause it's "beautiful? When I bought mine and found out the ratio was short I personally called him and was politely told he had never had a complaint.
    Consider my post as a free "bump" for Jim the OP.................................
  9. alchemy
    alchemy
    Rudestude, those sure look like Ansen to me.
    rudestude likes this.
  10. Fordors
    Fordors
    For sure they are Ansen, but they are for the early V8 Ford three bolt master cylinders, unlike the more often seen GM truck clutch/brake master.
    Also yours are for a floor mount application unless you add tabs for the pedals to work firewall mounted.
  11. alchemy
    alchemy
    Rudestude just has his mounting bracket upside down. Nothing unusual about his set. I’ve seen plenty that fit the Ford cylinders.
  12. rudestude
    rudestude
    Correct it is upside down, so that the mount was more visible for the photo.
    Also if I do use it I will be fitting it with a another plate with bolt holes that match the master cylinders that I will be using.
    Here's a page from my 67 Honest Charley's catalog plus a couple that I saw online. 20200106_195502(0).jpeg 15783699843094641687912683184664.jpeg 15783701344547001864709615461410.jpeg
