white wall info
Discussion in 'The Hokey Ass Message Board' started by goldflake, Nov 22, 2010.
  1. goldflake
    goldflake
    I have a question regarding picking white walls. im building a 1931 ford pick up and I have a set of 1937 spoke wheels..I have (2) 17 inch wheels and (2) 16 inch wheels and man I am having the hardest time picking a set of wide white walls. does anyone have any ideas...i looked at the croker tires website and im still lost......could I put the 17 inch wheels in the back and the 16 inch wheels in the front?
    any help would begreat thanks
  2. SixFive
    SixFive
    If they are Ford wires the 17" are '33-'34 and the 16" are '35.
    I would run the 16's on the rear with a larger tyre, 7.50 always looks good with the 17's on the front.
    Or look for 2 more 16" wires, they are always around.
  3. goldflake
    goldflake
    what about ww size....
  4. xlr8er
    xlr8er
    I just went through this with my project. I'm using 15"/16" wheels and the wide whites are 3" in the rear and 2 1/4" in the front. They look right... 205/15's up front and 235/16's out back. Hope this helps....
    Jim
  5. goldflake
    goldflake
    if i run the 17 inch in the rear with a firestone 600/650-17 and run a 600-16 in the front..does anyone have this combo....the 17 inch rim is 4.5 inches and the 16 is 5 inches will the front tire look fater then the rear?
