Technical Where the hell does the felt washer go on early Ford kingpin
Discussion in 'The Hokey Ass Message Board' started by adam401, Feb 28, 2019.
  1. adam401
    adam401
    I've searched and looked at stuff I have kicking around and can't nail down a firm answer on this thing. On 33 34 Ford passenger car kingpins where the thrust bearing is on top of the spindle, where if anywhere, do you use a felt washer with felt cup.
    I know on the later style kingpin with no mechanical brake cup the felt and cup go on top of the spindle but I'm pretty sure that's not the case with these.
    Feel free to bust my balls its ok I should know this.
  2. Dooley
    Dooley
    from Buffalo NY
    Yes
    adam401 likes this.
  3. adam401
    adam401
    Thank you for the replies. So I guess it goes like this? Its weird I have a couple spindle sets here and none had these washers in place.
  4. alchemy
    alchemy
    I don't think so. The weight of the car would crush the tin washer and felt.
    adam401 likes this.
  5. adam401
    adam401
    I feel like it goes between the axle and the bottom boss of the spindle but don't know.
  6. 19Fordy
    19Fordy
    Opps! Time to start over. Here's the parts pictorial from Green Book. Seem like 33-34 are a different set up than later years. The little felt washer #3288 does not go under the king pin head. It fits into retainer part # 3125 and is inserted onto the lower steering arm. In later years the little felt washer did fit directly under the head of the Spindle bolt. The spindle bolt lock nut determines the pre-set "crush" on the felt washer and retainer. Sorry for the double pix. IMG_4614.JPG IMG_4632.JPG IMG_4630.JPG IMG_4630.JPG IMG_4629.JPG IMG_4628.JPG IMG_4627.JPG IMG_4626.JPG
    lothiandon1940, pitman and adam401 like this.
  7. 19Fordy
    19Fordy
    Adam is correct.
    adam401 likes this.
  8. adam401
    adam401
    19Fordy Thank you for going through so much effort to answer my question I really appreciate it!
    lothiandon1940 likes this.
  9. adam401
    adam401
    I have to get a copy of the green book.
  10. tfeverfred
    tfeverfred
    adam401 likes this.
  11. 19Fordy
    19Fordy
    tfeverfred: 37 to 41 are a different animal than 33 and 34.
    ADAM: That BIG GREEN BOOK is a life saver. Available on Ebay and Fordbarn.
    lothiandon1940 and adam401 like this.
  12. tfeverfred
    tfeverfred
    Hey, I took a shot.
    OFT and adam401 like this.
  13. greg32
    greg32
    from Indiana
    under the kingpin, on top of the axle. holds the grease in, keeps dirt out
  14. adam401
    adam401
    Just an update. I put the kingpins in with new bearings and the felt and cups in the correct locations. Fits right and steers easy. 1551471183587269118822.jpg Thanks for all the help
    Yes I will wipe off the excess grease.
  15. adam401
    adam401
    Another observation. While searching for the answer to my original question I read a few times about people removing the mechanical brake cup to clear juice brakes. My 40 brakes clear fine without modification. So no need for me to remove them as far as function goes.
    Maybe its necessary for other setups I don't know. Certainly you could achieve a cleaner look by removing them but for me I like them on there.
