Projects where do i go with this dash?
Discussion in 'Traditional Customs' started by thewishartkid, Apr 10, 2018.
  1. thewishartkid
    thewishartkid
  2. Frankie47
    Frankie47
    from omaha ne.
    would you care to elaborate.......your'e a little vague on the details.
  3. thewishartkid
    thewishartkid
    I can't get an idea where the builder was going with this. All welded up with this console coming out of the middle of the dash.
  4. DdoubleD
    DdoubleD
    from Michigan
    Clean your camera lens.
  5. doyoulikesleds
    doyoulikesleds
    from what i can see most of it would go to the scrap yard. what car are you building and what is your final vision?
    Hnstray likes this.
  6. i bet he was going for something like this: Unknown-1.jpeg Unknown.jpeg
    ct1932ford likes this.
  7. 41rodderz
    41rodderz
    from Oregon
  8. maneri
    maneri
    from ohio
    time to start again --cut it out
    kadillackid and Hnstray like this.
  9. Remove that over sized waterfall coming out of the middle of the dash first, then give it another think.
  10. Some things look a lot better from a distance. I don't think you can get that far away.
    The Wizzard
    lakepipes, vtx1800, pat59 and 2 others like this.
  11. That rusted steel tongue sticking out of your dash has to go. The rest is pretty simple....cut holes in the driver's side, install gauges. Grab a glove box and door at u-pull-it and weld that sucker in the right side. Put switches in the middle. The end.
    vtx1800 likes this.
  12. miker98038
    miker98038
    The builder was going someplace none of us want to go, obviously. I hope the steering wheel was a mock up too.
    lakepipes likes this.
  13. Bandit Billy
    Bandit Billy
    I'd start by removing the console and dash connection piece. That is just nasty IMHO.
  14. Is that a Wrecking yard in the back ground? Might give you an idea of what the builder thought of what he had done.
    The Wizzard
  15. Cut out that center console and use the steel to patch the floor.
