History When did body panel-door gaps become an issue?
Discussion in 'The Hokey Ass Message Board' started by crminal, Jan 21, 2016.
  1. I'm working on a 57 f100 and am attempting bodywork. This truck is in great shape actually.
    But, I can't tell you how many "advisors" assume that I'm gonna gap the doors with a paint stick. Build up or shave the edges as needed.
    Not gonna be a show truck or a custom, just a nice driver with an old rod flavor, maybe even scallops.
    When did nice "dailys" get their doors gapped? Am I missing something?
    It's my intention to do go work, but....
    EDIT- got rid of the scallop pic. Trying to stay on the door gap question
    volvobrynk and Model T1 like this.
  2. In the $$$$ 80's. And now of course computer-built cars are all over perfect gaps. Don't sweat it, gapped trucks are poofy.
    :D
    :D
    I won't be gettin' mental with my 50's sedan. Just as long as they ain't fugly. Yours look OK- cool truck.
  3. Crusty Nut
    Crusty Nut
    It's largely from the car shows on TV and the posers that learned a new word. I'll bet every one of your "advisers" has a nice old vehicle with gapped doors, right?:)
  4. Spoggie and Crusty Nut, appreciate the input. Kinda what I was thinking.
    If it were 1960 and a guy was fixing up his truck, would he give two shitz about the gaps?
    I think not.
    loudbang, volvobrynk and Model T1 like this.
  5. Thanks. My old car has gaps all over the place, they kinda came that way, more or less. I heard the good ones were set aside for black paint/ bigtime customers.
    Mine ain't one of those. The gaps ain't too bad, but there are panels off 3 or 4 cars on it. I'll jack it/shim it- the key for such low-buck things is to try to hold a parallel negative space on each line, as well as you can. If the trailing/ leading/ top/ bottom has a differing space, so be it, as long as it ain't gross & works well. Each of my 4 doors will be a lil different, I guess. The hood is a biggie on my model. Lot of trial & error in my case.
  6. jcmarz
    jcmarz
    from Chino, Ca
    It started with the Gap Band.
  7. 49ratfink
    49ratfink
    door gaps became an issue when people began wanting to do quality work. if good enough is good enough for you then so be it.
    toreadorxlt, cretin, Russ B and 4 others like this.
  8. Petejoe
    Petejoe
    from Zoar, Ohio
    I agree. Never understood why gaps became so important to people. I Never gave two shits about them as long as they were even from the top to the bottom of the gap.
  9. oldolds
    oldolds
    Door gaps became an issue when a car company made a commercial with a ball bearing rolling over their gaps and the said it was a sign of quality. That is when the average person started to look at it. Before that a few guys with higher end shops would fuss with them on a restoration and make gaps perfect. I feel that most new cars by the late 60's had doors that should gap nicely with minimal care. Before that there was more of an acceptable tolerance range for gaps. I have seen some original 50's cars that had some poor panel fitment.
  10. joeycarpunk
    joeycarpunk
    from MN,USA
    "When did body panel-door gaps become an issue?"
    Only when uneven thick to thin or hitting the fender or body. Take a look at unrestored original cars for example very few if any were perfect. While impressive, cars with paint stick margins and no panel dive tend to look sterile sometimes and have no noticeable effect visually when driving down the street and used as cars.
  11. partsdawg
    partsdawg
    from Minnesota
    About the same time the term "over restored" came into use.
    As far as the comment about caring about quality,a quick look through the little car magazines of the '50's will reveal many vehicles have quality issues.The very best show cars may have had the time spent for perfection but the common man cars that make up 98% of the content appear to be good enough for the owners.
  12. i.rant
    i.rant
    1. 1940 Ford
    The first I heard of it was probably 25 or so years ago when I had the pleasure of visiting a restoration shop that was doing a 34 Packard headed to Pebble Beach.
    There was no "that's good enough" attitude in that shop, the attention to detail on those cars is inspiring to say the least and my visit there really taught me how to "look" at a car.
  13. Agreed.
    I generally don't attempt to exceed the original quality that the manufacturer expected at the time. If I do, it becomes a "custom" (not a bad thing)
    Gapping doors by shimming and finagling seems like good work. Trimming and welding seems excessive.
    In '57, a truck was not a lot more than a work tool. More likely it goes to, "the beach" than Pebble beach.
    Thanks all for the interesting perspectives. Keep 'em coming...
    '51 Norm likes this.
  14. Had to respond. Don't really know what to say though.
  15. I think it started right about the same time as clocking screw heads. :);)
  16. For a driver just get the doors adjusted as nicely as you can. Make sure nothing hits and go with it. All those built up edges are prone to chipping under daily use unless they were done right and built up with metal and NOT mud.
    loudbang, Atwater Mike and i.rant like this.
  17. "Perfection is the enemy of completion."
    Jet96, loudbang, '51 Norm and 10 others like this.
  18. In the 80's the rice rockets came on strong. At the car factory 1/8 was good on our tooling. The robots could get things tighter. Now the robots are in all the car factories.
  19. Many of my "advisors" seem guilty of this. Hmmm
  20. Mike51Merc
    Mike51Merc
    I guess I'm the oddball in this thread. When I see a car with bad gaps I feel that either it was wrecked in the past or the builder didn't care enough to fix them. If it had bad gaps from the factory I think of poor quality-control--- which now makes me think of OEM fiberglass hoods which never seem to line up properly. Maybe I'm a gap snob and never realized it until now?
    cretin, Squablow and crminal like this.
  21. Dan Timberlake
    Dan Timberlake
    I can believe that.
    A Massachusetts furniture company did a goof on that in a TV ad, trying to roll a ball bearing on a big fancy comfy couch. They used to have some pretty clever ads. Warren Buffet has since bought the company.
  22. PKap
    PKap
    from Alberta
    First time I saw that was a fat Jack built 53 ford truck in Hot Rod in the 80's. It was yellow and built like a Coddington Street Rod with no trim. On that build, the door gaps were the only line you saw in the Yellow, and would have been noticeable of they weren't perfect. On cars with chrome trim, a dark color or scallops like the OP, I don't think you even see the gaps. It is critical for a good looking ride that the body lines line up though, and worth adjusting if they don't.
  23. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Not critical, but I'll be doing mine on my truck. Paint stick, maybe not, but just getting them all the same. They're pretty wonky as of right now
  24. DDDenny
    I was thinking it started with the Corvete crowd and the over-restoring standards of the NCRS.
    Then I found this photo.
    loudbang and crminal like this.
  25. wicarnut
    wicarnut
    IMO, if your building a "SHOW" truck or car competing on professional level, gaps matters, like sooo... Many Details, drivers not so much. Free advice, EJOY the hobby and the people involved, that is the Fun part, Again IMO.
    loudbang and volvobrynk like this.
  26. DDDenny
    ClayMart likes this.
  27. Mike51Merc
    Mike51Merc
    OK, so putting paint-stick or Vernier caliper perfection aside, if you're assembling a car and the gaps look uneven from 10 feet away, you guys are saying to leave them that way?
  28. Man I really hate scallops. :p I just wanted to say that.
    I think that scallops became an issue when everyone began to think that even they could build a Ridler quality car. Its a fucking high zoot street rodder thing. Just build it and drive it.
    wicarnut likes this.
  29. Jeez Beaner, I apologized for the scallops...;):D
    volvobrynk and ClayMart like this.
  30. Atwater Mike
    Atwater Mike
    LOL I don't have scallops (or fire) painted on my F100, and door gaps are not perfect.
    Both doors are 'forward' (1/8", so the trailing edges are 1/4" wide) This is a rust free example that was assembled in '55, doors work smoothly...bugs me a little to see the gaposis, but when I get around to paint, they'll be shimmed at the hinges.
    But, as @irant reminds us, "IT'S A TRUCK!" So, show it or drive it.
    Just lose the scallops. I won't flame mine. Who'd want a 'Fire Truck'? :D
