Technical what year?
Discussion in 'Traditional Hot Rods' started by backrodebob, Nov 21, 2019.
  1. backrodebob
    backrodebob
    Ok flathead guru's I need help! I have a 29 ford model A with a 49-53 flathead, is there anyway to tell exact year other then #'s stamped on block? the only # I can see is something that looks like a 2....
  2. leon bee
    leon bee
    The ones I've had, no. Not that many, but I've found no useful markings. It hardly matters except for one thing: the last ones, many didn't have valve seat inserts.
  3. Van Pelts has the info.
  4. clem
    clem
  5. backrodebob
    backrodebob
    Hey guys, I narrowed it down to a 49, thanks for your help! Learning more about these flatheads every day.....
  6. clem
    clem
    Now for the pictures...........?
  7. backrodebob
    backrodebob
    Tim, KoolKat-57 and dwollam like this.
  8. It doesn't really matter because they're basically unchanged throughout the last years, but someone already mentioned Van Pelts and you figured it out. Mine had a factory relief for the valve to cylinder area and valve seat inserts. Some do not have that. All of the parts will interchange.
  9. backrodebob
    backrodebob
    yup! I found that out!
  10. backrodebob
    backrodebob
    Have any of you repaired a spark plug threads while head on the engine?
  11. deathrowdave
    deathrowdave
    from NKy
    Yes I have , not sure it’s the correct type of repair . But when your bike blows a plug , what else are you goin to do ? I greased up the drill bit and tap and cleaned with carb spray , lock tight on the insert . Screw the plug in and light the brute and go man go .
