Technical What is this rearend
Discussion in 'The Hokey Ass Message Board' started by 327Eric, Aug 16, 2021.
  1. 327Eric
    327Eric
    IMG_20210816_140320.jpg IMG_20210816_140301.jpg IMG_20210816_140307.jpg I told my buddy I wanted to upgrade the rearend in my 59 ElCamino and he came up with this, narrowed 4.10 full floater with an Eaton posi I believe it's early 60s Chevy truck. It is a bolt in to a 59 ElCamino. It was built by the owner of RCD engineering many years ago. It comes with the 15 inch 8 lug Ansens. Can anyone positively ID this. I have not seen it yet,
  2. lostone
    lostone
    from kansas
    1 ton truck rear end..... I'm guessing old ford....
  3. squirrel
    probably 60s-72 chevy truck. I don't know when the brakes got smaller diameter like that, they were narrow in the late 50s.
    probably has a casting date code on the center section, and you can figure out the shoe size and do some looking on rockauto to see what years those were available. And probably date code stamped on the ring gear, as well, if you take it apart.
  4. jaracer
    jaracer
    The pumpkin sure looks to be a 9 in Ford. It has the removable pinion housing.
    Johnny Gee likes this.
  5. Agree with Squirrel, that removable rear cover is like the 3/4 or 1 ton Chevy truck rearend. 8 lug is truck for sure.
    Lloyd's paint & glass likes this.
  6. Jmountainjr
    Jmountainjr
    Just because you can doesn't mean you should. Lots of better choices available out there that you would be happier with in the long run.
    Hnstray and Bob Lowry like this.
  7. lostone
    lostone
    from kansas
    ^^^ agreed^^^
    No way I'd put that under a elcamino.... 1 ton truck maybe....
  8. Many years ago.... Guys forget that these were once fairly popular with some racers before high-strength aftermarket axles became available. Most came with low ratios, were tough enough to take a serious beating, and because they were full-floaters, a broken axle wasn't a disaster.
    arkiehotrods likes this.
  9. squirrel
    yeah, but so do 3/4 ton and up Chevy trucks from long ago....maybe you never looked at one?
  10. jaracer
    jaracer
    I've got a 64 Chevy C20, but it's got a Dana in it.
  11. lostone
    lostone
    from kansas
    Yep, have a good friend that use to race a late 50's early 60's vette at mo-kan years ago with a 1 ton rear and 5:13 gears if I remember correctly. 265 small block chevy that left the line at 10,000 rpm and rear bumper scraping the track then shift at 8000.
    Would have been faster with the nose down but wouldn't have been as cool to watch or as well known back then.
    Buddies used to say the best part was watching the starter flag men when it hit 10 grand as thet dropped the flags. Said some of the flag guys would about hit the ground the minute the clutch was dropped and it stood on its tail.....
    Ah the good ole days.....
  12. landseaandair
    landseaandair
    from phoenix
  13. 327Eric
    327Eric
    There are better options sure, but they cost a hell of a lot more than 300 bucks, and don't have the old school cred. It's a bolt in. Don't know if or how long I will use it. I an building a pretty stout 383 with a crossram and a 4 gear to put in front of it. Look up RCD engineering, it's a cool lineage
    arkiehotrods and blownhemi48 like this.
  14. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Do the five lug front wheels have the correct bolt pattern for the El Camino? If so, you don't have much to lose by installing it. Probably get a lot of conversations about it later on.
  15. 327Eric
    327Eric
    It's the matching front and rear wheels that were run on his 59 ElCamino back in the 60s or 70s. I have always leaned towards the old school street racer theme, and think it's pretty cool. He got tired of chucking spider gears too.
