i am going to do some work on a project for a fellow and this is the chassis i am to use... what is it early dodge perhaps? im gonna make a fenderless hot rod truck i think out of it with a tube axle on the springs on it now on the front. kind of up in the air gasser style ford cab yada yada. but I would like to know what the thing is.?????????? I know within mere minutes i'll know and thanks in advance... the owner said it had he thought like a wide five wheel and wood somwhere on the wheel or hub. im thinkin early dodge 28 or so and the spidle is a strange deal see picture
There was another thread yesterday on 34 Chev wires.. the odd pattern on the Standard Series was 4.25 bolt circle with 5 lugs. Same year but the Master Series was 6 lugs.
i thjought gm /chevy too but has wooden wheels or centers wood...dodge is only one that comes to mind but not sure about the front spindles ?
Looks like 28-29 Dodge. It should have serial # stamped on side of frame pass. side, behind front wheel. 28 was also frist year for DeSoto.. Does the front axle have brake drums? If you find the serial #. P.M. it to me, i will try to figure what it is O.Hove
If you knew how fast Sam can put together a car, you would realize that after 2 years and 9 months that this frame is already driving around under its own power.
Could be a 1929 or 1930 Dodge Brothers frame. It is definitely NOT a 1931 Dodge frame. I have two of them and they are like this....
