My club is trying to put together a Model A rail job for TROG. We have a built 4 cylinder banger and a 1934 top loader. Our resident mechanical "jenius" can't figure out how to put this puzzle together. Is there an adapter that's out there, or is there a better/cheaper/easier way?
Crucial point. By the way I think the club should replace your jenius with a genius, it may help. LOL
I believe the 40-41 4 cylinder engine is from the 9n tractor. Completely different engine and nothing interchanges, including transmissions. Farmalldan
"What does it take to marry a 1934 trans to a Model A Banger" The State of California and a justice of the peace with absolutely no prejudices.
Use the model B(32-34) top flywheel cover. It only goes halfway around though. The bittom mount was the rear part of the oil pan. Put a wanted ad up for the rear part of a 32-34 4 cyl oil pan and upper flywheel cover both here and on Ford barn. The parts are out there. Then if you dont split wishbone you need a bracket to mount the wishbone to the trans. Also the pedals used to mount to the A bell housing. Not anymore. You need a bracket that attaches to the shifter top bolts and the bellhousing bolts and has a pedal mount. I believe you also need a different clutch release lever/crossshaft. Check with The Model A Store in Colorado. They might have the brackets. Scott
Oops, my advice above is for a B trans. If its a v8 trans you need a different adapter from engine to trans.
