Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. Jack Wagon
    Jack Wagon
    from Ferguson
    6291D25C-7445-4AE3-8CD8-0DDBB0FCBC32.jpeg Went out for a midnight ride…
    hotrodjack33, 40two, loudbang and 3 others like this.
  2. WB69
    WB69
    from Kansas
    Put battery tenders on everything.
    blowby, Lil32, loudbang and 2 others like this.
  3. Jkmar73
    Jkmar73
    from Tulare, CA
    Made up linkage for the clutch pedal to master. And made a paper template for the radiator fan shroud.
  4. Balljoint
    Balljoint
    Nothin, it's been 3 degrees outside all day.
    210superair, Lil32, loudbang and 2 others like this.
  5. junkyardjeff
    junkyardjeff
    Nothing here today,it rained all day so I stayed in building models.
    dehartcarl, Lil32, loudbang and 3 others like this.
  6. buzz4041
    buzz4041
    from Texas
    Worked on polishing the gas tank today. Still got a way's to go. She was pretty rough to begin with. Gas Tank10.jpg Gas Tank15.jpg
    40two, Joe Blow, 210superair and 12 others like this.
  7. Parts should arrive tomorrow . Time to tear down, check engine, run the valve adjustment, check blower , reseal valve covers, replace thermostat housing and polish. Reseal water pump, upgrade trans mount, new spark plugs, change rear diff oil, polish everything and more polishing. Check and inspect more stuff, this will go on and on all winter just like every winter. Spring is coming, believe it or not.:) Oh yea, I am looking for a BIGGER blower.;)
  8. Pardon my curiosity @mad mikey , but how goes the healing process?
    mad mikey likes this.
  9. Thanks so much for asking. I am just fine and ready for, hopefully a better year, for all of us. Happy New Year friend.:)
  10. Oh I forgot, got the upgraded trans mount installed and did some cleaning-polishing underneath .;)
  11. Cut some splines in my shortened drive shaft
    Chappy
    20220101_203719.jpg 20220101_203712.jpg 20220101_193915.jpg 20220101_184415.jpg
  12. Almostdone
    Almostdone
    Put the newly-balanced driveshaft in. I had a local machine shop shorten it for me, but never had it balanced; I have about 2,200 miles on the car. Probably have to wait for next spring to see how much nicer it drives now.
    John
  13. TA DAD
    TA DAD
    from NC
    Got my headlights installed , along with the fenders. IMG_0004 (3).JPG IMG_0003 (3).JPG
  14. Attached Files:
    rod1, Joe Blow, mgtstumpy and 9 others like this.
  15. I gutted the engine compartment & pressure washed it preparing to repaint the inner structure as it is supposed to be body color. Removed the grill, bezels & surround to be sent out for re-chroming. I need to get the steering box out so I can send it out to be rebuilt. Lares has no cores to do one for me ahead of time.
    God Bless
    Bill
    https://www.jalopyjournal.com/forum...ar-transport-hauling-open-or-enclosed.614419/
    BakonBittz, 40two, Joe Blow and 9 others like this.
  16. topher5150
    topher5150
    Might get a little more motivation to work on it this winter IMG_20211231_143436632_HDR.jpg IMG_20211227_171112210.jpg
  17. Started, and almost finished, my radio replacement. The more I dug, the bigger the hole. Replaced the instrument lights with LED's and also removed the CD changer.
    The old...….
    The new, Wonder Bar look-a-like with AM, FM, Bluetooth.
  18. TA DAD
    TA DAD
    from NC
    In keeping this truck with a "as found in the woods " appearance I have cleaned up and sanded down all the peeling chrome on the YANKEE brand turn signal lenses and have those re-installed. Also replicated a mirror stand for the drivers side to match the one on the front fender. These are some ugly ass mirrors but they were what was on this truck, probably from the start as there are no other mounts or holes. But I do have a nice pair of doors with matching factory mounts so at some point those doors may get swapped out. Right now I just want to get this thing on the road and the doors do not help reach that goal. I also got the instrument cluster back in place ( none of it is hooked up ) Over look that shitty China air cleaner it is temporary !
    IMG_0036 (1).JPG IMG_0033 (2).JPG IMG_0034 (1).JPG IMG_0031 (2).JPG IMG_0019 (3).JPG
    Lil32, Joe Blow, mgtstumpy and 10 others like this.
  19. TA DAD
    TA DAD
    from NC
    I installed some lap belts in my old truck today. Fabbed up some mounts out of 1/4 in. plate. I still need to run a bead on th IMG_0040 (1).JPG IMG_0039 (1).JPG IMG_0042 (1).JPG e bottom side I just wasn't up to it today.
    Lil32, Blues4U, RICH B and 8 others like this.
  20. connielu
    connielu
    1. A-D Truckers
    Finished restoring the stock speedo and gauge assys, replaced the tank sender to match the 30 ohm stock one, rigged the horn with a button (need to replace the shorted upper mast bearing/contact).
  21. mgtstumpy
    mgtstumpy
    Body is FINALLY back on the frame, let the fun begin!
    40two, Lil32, mad mikey and 14 others like this.
  22. Kinda slacking it for a while; getting cataracts fixed. Finished up, primed, and undercoated all the fender braces/gravel shields for our '47. Made some "staples" out of safety wire to hold the rubber seals (good for poking fingers too) to left rear piece. Heated and bent a piece of ABS to make a heater hose cover for under the dash; picture looks goofy; but the radius is even end to end. Stripped the remaining paint off the diecast dash trim and cleaned and primed it. Made up some hand brake cable tubes for another job.
    John was up at the shop working on his truck project; trying to get his poorly aligned throttle cable to work. Of course I had to point out that his parking lights came on when started the engine, checked and tail and dash lights came on too. I thought it was funny; he didn't. Figured out if we pulled the dash light fuse they went out. Guess I'll have to do a little sleuthing on how this came about; acts like it is a ground problem; but the fuse deal throws that a little.
    2022-01-13 15.38.27 (Medium).jpg 2022-01-13 16.05.30 (Medium).jpg 2022-01-13 13.44.44 (Medium).jpg 2022-01-13 14.03.55 (Medium).jpg
    Algoma56, 40two, mad mikey and 5 others like this.
  23. lumpy 63
    lumpy 63
    Fabbed up a tilting table for the mill so I can do machine work on old cast iron sbc heads like cutting em down for screw in studs and guide plates + machining them for pc seals. The prices at my local shop have forced me to do this myself as I cant fathom spending $1000 on an old set of fuelies for a nostalgia type build.
  24. lake_harley
    lake_harley
    Didn't get this done today, but this is how far I got. ;) I've been piecing together a FED for a few weeks as my seemingly hectic retirement schedule permits. Other than the cage, the chassis is mostly fitted and tack welded. It will be 145" wheelbase with a mild SBC and a full length Powerglide. Having fun bracket racing is the goal and hope it to be a 6.80 to 7.00 car in the 1/8 Mi.
    FWIW.....I'm the ruggedly handsome gentleman shamelessly posing in the photo. :D
    Lynn
    chargin03, rod1, Algoma56 and 24 others like this.
  25. samurai mike
    samurai mike
    i drove to the store and got 12.5 gallons of gas for $50!
    lurker mick likes this.
  26. saltflats
    saltflats
    from Missouri
    Transmission installed for the last time and the pedals hung.
    mgtstumpy, blowby, Joe Blow and 8 others like this.
  27. Almostdone
    Almostdone
    Installed the newly-balanced driveshaft. Oh boy.
    John
  28. Put some Ford Wimbeldon white on the die cast dash trim for out '47. Decided the best place to put it so I didn't damage it was on the car, so I drove up to the shop and installed it.
    I hadn't put the column in since I needed the room to access the trim screws, once trim was in place, stuck the column in too. Even remembered to put the keyway down.
    Wanted to put the speaker grille and vertical trim on too; but I didn't think to bring them.
  29. My buddy has one of those in the woods behind his place up north. Gave it to me at one time; but later (maybe 25-30 years) changed his mind and decided it needed to stay out in the woods. P9060022.JPG P9060025.JPG studeleftside.JPG
  30. heading to its closer home !
    phelan9251 likes this.
