Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. gimpyshotrods
    gimpyshotrods
    Today I fired up the cold saw, and cut the frame pieces and control arms for my next chassis.
    Now I am mopping up the excess coolant.
    I do enjoy the accuracy of this saw, but it makes quite a mess.
    chryslerfan55 and j hansen like this.
  2. Those things are great.
  3. fastcar1953
    fastcar1953
    Spent the day with friends. Food and friendship. Nothing better. 132144903_3888664984513125_1893035330463042210_o.jpg 133725611_3888666074513016_7992894448445512949_o.jpg
  4. gimpyshotrods
    gimpyshotrods
    Today I replaced the 19-year-old water cooled torch on my TIG welder.
    It is not a comforting feeling to hear the distinctive sound of your foot setting down in a puddle, when you move to the next welding position.
  5. I permanently attached extension to the fender and bolted it on the car; onto the right side nest week.
    Need to find where I have more of the sheet metal stashed.
    IMG_20201231_151738_1 (Medium).jpg IMG_20201231_151750_3 (Medium).jpg IMG_20201231_151806 (Medium).jpg
  6. gimpyshotrods
    gimpyshotrods
    Today I did the majority of the work to turn my drop pile into a wheel building jig.
    First up: wider Wide-5s. PXL_20210103_015154856.jpeg
  7. jimmy six
    jimmy six
    Adding a PCV system to my 56 Ford Y-Block with the correct 64 valley cover and fitting. Won't fit the dual quad manifold hits the back so I modified it. Used my oxy/act unit. Pretty thin material. Something no one sees. Cut with 4” disc. Didn’t trust my welding on the original top trimed off. Pain in the butt for something no one will ever see..
    61CBE22C-B7A3-40E8-9C72-33F4BC878E6D.jpeg 8BDF6C24-1C2B-4946-B4A1-DEE362D0481A.jpeg 673ACF3A-CDD8-4DC7-8094-C4150EA8432D.jpeg
  8. Boneyard51
    Boneyard51
    Went to a new huge salvage yard today. Can’t show you the convertible, one year too new. But did see three totes full of 9 inch rear ends where they cut the third members out a torch! Saw a couple of early nine inch housings in there, or what was left of them. Crazy! Then stumbled on another pile of pumpkins! Had fun tho!
    Bones 123722DB-2196-408D-8735-888C6D936474.jpeg B68BB376-E3F4-4089-8AC0-5C2306D6422B.jpeg
  9. Poverty cap
    Poverty cap
    On my 62 Belair the last couple of days I reworked some bodywork I wasn’t happy with masked it up an sprayed it with polyester primer, and I’ve been blocking out the door drivers door. A78E1E08-6EFC-4321-946B-28B1AF02E99F.jpeg 3EF14E86-CF65-479E-899E-4988C209CA61.jpeg
    mad mikey, 40two, LAROKE and 6 others like this.
  10. saltflats
    saltflats
    from Missouri
    Sent a E Type restored rear suspension out the door. :)
  11. Almostdone
    Almostdone
    Helped one of my brothers get his car on a rotisserie
    3B4B19A5-8549-4D94-8664-F74E9DE1F1EF.jpeg A34F2714-9EF8-49F8-85ED-73A57BE81882.jpeg 7CEB1C70-D1C6-4F67-AFD8-A36F81FC0115.jpeg 7B20DDF5-AD7B-4455-BA27-CFAD4744E6FA.jpeg 0EFBC505-0E7A-4075-9C0C-47542672353C.jpeg
  12. 31hotrodguy
    31hotrodguy
    My oldest son decided to take over the 57 210 9 passenger wagon. We spent some good bonding time scrapping rust and old grease! IMG_3943.JPG
  13. Greg Rogers
    Greg Rogers
    Removed left rear fender and left running board- surprised how solid it is. Going to remove box and go to work on rust.
  14. Made the r/h fender and extension one and installed it along with some more sheet metal on my '47. Brought up a new question; does the front pan go on top of the inner pan as I have it installed in the picture, or does it go under it? Looks like it could go either way. The green book doesn't show the inner pan in place.
  15. gimpyshotrods
    gimpyshotrods
    Finally moved the last car to the new shop.
    Mine.
    mad mikey, rod1, Jalopy Joker and 2 others like this.
  16. SmokinBill
    SmokinBill
    Got a break in the weather, So we took her out for lunch
  17. saltflats
    saltflats
    from Missouri
    I cooked dinner for my wife before she has to leave work for the night shift. I couldn't do what I do without her hard work and dedication. ;) :)
  18. 32 hudson
    32 hudson
    Installing more heat in the shop with cast iron radiators in the forced hot water system.
  19. j hansen
    j hansen
  20. Greg Rogers
    Greg Rogers
    Love that 55!!!
    mad mikey and Lil32 like this.
  21. Lmao! I love this thread :D
  22. Norris McCarty
    Norris McCarty
    Figured out an air filter that would fit my Grace & Company air cleaners. I still can’t use the nice wire insert with these filters but they do flow enough air and they do filter the air! I’ve got the Wix and K&N part numbers if anyone is interested.
  23. Marty Strode
    Marty Strode
    It was nice day, so harvested a 9" rear from a 74 Van, was able to do it with sockets, wrenches, and pliers. Nice to be able to save the u-bolts, E-brake cables, clips and all. It would make a narrow rear with big brakes and 5-1/2" bolt circle, and will reside on my roll around cart with others. IMG_6145.JPG IMG_6146.JPG IMG_6147.JPG
  24. gsjohnny
    gsjohnny
    got new neighbors. so i started the dragster up at supper time. will see what tomorrow brings. :D:D
  25. HotRod33
    HotRod33
    Started unpacking new winter's quick change
  26. john W.
    john W.
    I installed Aftermarket AC for my wife in the old caddy.
  27. Jalopy Joker
    Jalopy Joker
    - take her out for Hi-Octane?
    - look but, don't touch - Ha!
  28. gimpyshotrods
    gimpyshotrods
    Today I put up more shelves in the new shop.
    Then I pushed broom, mopped the entire floor, and dumped the chips from the CNC.
    All work is important work. No job is too small.
    Now, I am busting out the Blanton's Gold Edition, and having a birthday drink.
  29. Stock Racer
    Stock Racer
    Got the block back from the machine shop and doing some head work on a 327 for my 62 Biscayne IMG_2491.jpg IMG_2492.jpg
  30. We rescued this old rock solid Model A body, for my friend’s project chassis on Saturday IMG_1360.JPG
