Technical What did you do today?
Discussion in 'The Hokey Ass Message Board' started by Daniels Auto Repair, Jul 9, 2016.
  1. David Gersic
    David Gersic
    from DeKalb, IL
    Installed helicoils to fix the stripped threads for the transmission inspection cover, while I can reach them to do it. Had to remove the starter, but the oil pan was already out of the way.
    Oil pan, filter, and inspection cover back on, buttoning up the bottom side of things finally.
    New lifters, pushrods, and rockers installed. Preload set.
    Installed the intake manifold and accessory brackets. Torquing down the last intake bolt, discovered that the threads are stripped out of the hole. Probably explains why that bolt loosened up on me and caused a coolest leak last year.
    Swore a bunch. Removed intake and accessory brackets. Cleaned up the resulting mess.
    Now I need a 3/8-16 helicoil kit. OReilly’s web site says that they have one in stock.
  2. Met up with my good friend Timmy, for some BBQ. It was his first time out in his Chevy. Since having both his knees replaced. Technically it would've been yesterday as I'm posting a little late.;) Lol Ron.... 20190330_183752.jpeg 20190330_183411.jpeg
    Sent from my SM-G920P using The H.A.M.B. mobile app
  3. pecker head
    pecker head
    23EF8E76-9F49-462C-8183-8153F5590A82.jpeg 80F51AD2-0B87-4244-9DA8-7FD2C0FE0096.jpeg F0E9BE10-5DAB-4DEA-B520-907F308E6CE4.jpeg Drilled rear backing plates.
  4. 62rebel
    62rebel
    Took the front seat out of the Galaxie to work on the sliders. Broke three bolts. Couldn't find a missing steel ball or come up with a substitute, but did manage to get enough white grease in them to make them work for the time being. With working slides I can get enough room to work without having to remove the seat (again).
  5. MMM1693
    MMM1693
    Hey Dane, maybe if you didn't spend so much time with your friend on the welding table you would get something done!
  6. ...went to a garage/estate sale, these A's were for sale, pretty pricey tho, $25,000-30,000....pickup was my favorite, bought some neat Ford postcards and 4 diecasts...
    model a's rochelle sale 3-30-19 001.jpg model a's rochelle sale 3-30-19 002.jpg model a's rochelle sale 3-30-19 003.jpg model a's rochelle sale 3-30-19 004.jpg model a's rochelle sale 3-30-19 006.jpg model a's rochelle sale 3-30-19 005.jpg
  7. Crocodile
    Crocodile
    41 ford.jpg Got this really solid 41 Ford sedan today. Didn't need another project, but you know how it goes...
  8. pecker head
    pecker head
    5F59043D-FDE2-4785-8736-4F29844A5A24.jpeg I wiped the dust off of Mama Pecks BLACK FRIDAY MERC, try to get it decent for ROUNDUP.
  9. UNSHINED 2
    UNSHINED 2
    Yeah, Blondie needs to get off the bench......takes up WAY too much valuable working space!
  10. 1971BB427
    1971BB427
    from Oregon
    Got the '35 Plymouth chassis to real roller status today! Ready to drop engine/trans in and run the exhaust system. Just some junk tires/wheels for now.
  11. oldsfrench
    oldsfrench
    from France
    Sorry for poor english. .
    Spend a Day long in the garage
    First fix ignition on my 1956 olds 98
    check the carburator
    It had à leaking float
    Hoppefuly i have a second carb for donnor
    Put a New water pump .
    All seems to be OK now
    Next Saturday i put the car on the road for first driving test since i put the complète rebuilt engine and trans
    (Jetaway )
    Sorry no pics
  12. Went to williford and met a guy there and sold him a truck seat. Since I was there I hooked to my Sons Ot 72 chev Pk with my wrecker and towed it to my place. His turbo 350 trans took a dump. If it was mine I would cut a hole in the floor and install a granny 4 speed.
  13. David Gersic
    David Gersic
    from DeKalb, IL
    Well, OReilly’s computer lied, no helicoil kit. Found one at AutoZone, after doing the “year, make, and model?” dance.
    Got the intake and accessory brackets back on and torqued. Getting closer.
  14. 62rebel
    62rebel
    Decided I needed to get my shop shed straightened out so I spent all afternoon tossing out crap. And, ironically, even though I didn't know I had one, I found a dimmer switch pigtail for the Galaxie! Oddly enough, I often find stuff that way. Also found out I have a Mustang mast jacket upper collar that I may be able to use for the Galaxie.
    osage orange and Hombre like this.
  15. WB69
    WB69
    from Kansas
    Had to do some pasture burning. That time of year....
    osage orange likes this.
  16. fastcar1953
    fastcar1953
  17. CAVEMAN_1960
    CAVEMAN_1960
    from Michigan
  18. Checked firewall to valve cover clearance, again.
  19. brasscarguy
    brasscarguy
    from seattle
    Recently moved to a new home and shop space. I thought the move was a big deal but now outfitting the shop is going to be a lot of work.
    After a lot of thought and design was completed we installed my 15' Harrison lathe and 42" milling machine. Now the hard work begins,
    This weekend was building the main work bench. Steel legs and a nice metal top. Then is was repurposing several used metal drawer sets and cabinets. Removed all drawer fronts and doors sanded primed and finish painted 12 drawers and 4 cabinet doors. They are now drying to be reinstalled later this week. Need to get the bench up and running with all drawers and cabinets to put tools in so I can continue to work on the shop. Photos to follow later this week. I'm setting aside the spring and summer to get the shop in order for car work to start September 1st...………….come hell or hi water
    just sayin'
    brasscarguy
    chryslerfan55 and mad mikey like this.
  20. MMM1693
    MMM1693
    UNSHINED 2, the unibody really starting to take shape! Nice work. Looking forward to our mid May rod run. I pretty much just have spring fire up and clean up to do to either one. Get this cast cut off in two weeks and then a walking cast or boot for two more. Catch you later.
    chryslerfan55, Deuces and UNSHINED 2 like this.
  21. UNSHINED 2
    UNSHINED 2
    Yep, its coming along. Slow stuff for the next w 20190401_115231.jpg 20190401_115019.jpg eek or so. Rebuilding the other cab mount. Crummy work, but I figure I better do it before hanging front sheetmetal and door on passenger side....
    Good to hear youre healing up. Bet youll be happy to be able to get around a little better. Be good for us all to be cruising come Mid-May!!!!!
  22. Bandit Billy
    Bandit Billy
    Grabbed a beer with a friend at the local watering hole on a beautiful Sunday afternoon. He just bought this 50 a couple weekends ago and hasn't got out of it since. 13,000 original miles, plastic covers on the seats, all original other than a little drop and some pipes.
  23. Wow, that's a clean shoebox!^
  24. blowby
    blowby
    from Nicasio Ca
    Trained in the Burn Trailer, a 300 degree roasting oven. That's me without a helmet on, looking ready to keel over. Senior member of the department overdue for pasture.
  25. Paul
    Paul
    Editor
    Almost done with the shrinker stretcher stand, just need to put some foot pads on and maybe paint..
  26. Paul
    Paul
    Editor
    Cleaned up and adjusted a sheet metal brake my brother in law gave me..
  27. fastcar1953
    fastcar1953
    primed and painted bed on my truck
  28. Paul
    Paul
    Editor
    And took an old clock for a ride, turned out the repair shop was closed, nice day for a drive though
