Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. mohr hp
    mohr hp
    from Georgia
    This is just too crazy, thank God you're still alive. I ride around my subdivision 4 days a week. I nearly had a head on with a neighbor in her new van 2 weeks ago, she was looking down at her phone when she got really big in front of me. I took an evasive to the smooth grass nearby, but I could tell she was pretty shook. You hang in there, and keep fighting through the rehab. I know you're pretty tough. Keep going.
  2. enloe
    enloe
    from east , tn.
    Well we got everything done on our list this evening.
  3. I got the black beast fired up today, was the first time this year, last November I was able to get it around the block a couple times before it was put away into winter hibernation.
    No leaks so it looks like I have a green light to give it a few more shakedown miles and get it inspected so it's all legal like again.
  4. shorrock
    shorrock
    20230121_160438.jpg 20250501_162614.jpg 20250515_203744.jpg The serpentine belt that drove the blower and the clutch started slipping at 3500 last year. Due to the high tension of the lousy belt the waterpump bearing started to fail as well so the engine was pulled and modified. The french flathead was converted to a 2" toothed belt and made the blower ratio a bit faster as well. I ground the cam for a bit more lift by grinding the bottom lobe. Sounds angry and has a nice rumble. Now I have a small belt running pumps and alternator and the toothed belt for the blower. Managed to pack it very tight so the engine got only 1,5" longer. The 9,5" clutch was replaced by a 11" clutch so hopefully this will hold the power. The firewall was remodeled around 2,5" so there should be no space problem - will find out this weekend. View attachment 6401416 View attachment 6401416 20250501_162614.jpg 20250515_203744.jpg
  5. saltflats
    saltflats
    from Missouri
    Got the spacers cuts and new long bolt's also got the turnbuckle adjuster. Think it turned out pretty good.
  6. Wanderlust
    Wanderlust
  7. jazz1
    jazz1
    Finally finished the frame,,,thought i had enough epoxy primer…not so..misted a thin coat on for now…. IMG_3484.jpeg IMG_3199.jpeg
  8. “Working on” motivation to finish my longer, lower, wider jailbird. Need to put aside an OT project.
  9. jeepster
    jeepster
    from wisconsin
    Glued up a door panel.
  10. choptop40
    choptop40
    That look ks sweet..
  11. BigRRR
    BigRRR
    Picked up a multimeter/dwell meter last summer. Last month found a rusted up Craftsman tool box in curbside free pile. Sandblasted/painted and just installed meter tonight. Perfect size for timing light and miscellaneous tune up tools. IMG_2547.jpeg
    4 pedals, alanp561, enloe and 19 others like this.
  12. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Sharpone and porkshop like this.
  13. 1pickup
    1pickup
    @BigRRR That material is the bee's knees!
    Wasted my time on this today:
    Before (left) & after (right). It looked much better in my mind's eye, than it did to my real eyes.
    401 Nailhead piston tops & cheap filters so my flathead can breathe better than with the old bonnet style.
    It looks better on the engine. I'll get some stainless acorn nuts for the top to finish them off.
  14. Dick Stevens
    Dick Stevens
    When you get them polished they will look much better! Oh and use acorn nuts instead of plain hex nuts to retain them.
    swade41, porkshop and Sharpone like this.
  15. jeepster
    jeepster
    from wisconsin
    Need some door pull handles. Luckily I had a old die in my stash to make the pull ends. IMG_2093.jpeg IMG_2091.jpeg
  16. Lloyd's paint & glass
    Paint.... sanding...... same shit, different day :D 20250519_161021.jpg
  17. scofflaw
    scofflaw
    from Ohio
    That's beautiful Lloyd!
  18. I like it, I agree that if you polish those it'll look even better, I might go rummage my junk pile and see if I have any pistons in the correct diameter.
    mad mikey and Sharpone like this.
  19. jeepster
    jeepster
    from wisconsin
    Installing door panels
    porkshop, enloe, mad mikey and 8 others like this.
  20. choptop40
    choptop40
    PXL_20250522_150204610.jpg Steering column sourced.... undecided on it ...Gauges look like they came from factory. .Took some doing. ..
    61Cruiser, porkshop, vtwhead and 3 others like this.
  21. Off the road temporarily...
    Got a bit of spring work to be done in the front end...
    OzMerc
    porkshop, enloe, Stock Racer and 7 others like this.
  22. I went a little backwards and went back and welded in this missing fender brace bracket that I robbed from the old fender.
    I probably should have done that before painting the fender lol, I also stripped the braces and gave them a coat of Por-15 primer and a couple coats of satin black.
    Screenshot_20250519_200733_Gallery.jpg 20250522_145848_01.jpg 20250521_170634.jpg 20250522_152945.jpg
    While waiting on paint to dry I made a new bone for the shrunken head out of the paintbrush handle.
  23. F-head
    F-head
  24. deathrowdave
    deathrowdave
    from NKy
    IMG_2813.png Just for anyone with mice they need to get rid of .
  25. HOTRODPOWELL
    HOTRODPOWELL
  26. Sharpone and 427 sleeper like this.
  27. Sandcrab
    Sandcrab
    Dave, must be that time. I found this in my metal pile inside the shop. I have had Rattlesnakes, but this turned out to be a Bullsnake. They eat the rattlers so I turned it loose.
    alanp561, porkshop, saltflats and 9 others like this.
  28. Oneball
    Oneball
    My AC has lost its gas, seems that the o ring around the plate that holds the crank seal in on the compressor has failed, pulled it off and took it to my friendly AC guy who is going to get a rebuild kit. Every now and again you’re really lucky and find someone who knows their stuff, especially on 50 year old AC systems; “had that problem before on combine harvesters” was his response.
    4 pedals, porkshop, saltflats and 8 others like this.
