Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. saltflats
    saltflats
    from Missouri
    Today was a trip to town to work on my good friends 62 SS Impala. Had a no spark problem. It has a 409 with a converted distributor that uses GM HEI module mounted external inside the car and had finally failed. Got it replaced and fired up then the fuel pump started leaking so replaced it. Next I need to figure out what's up with the brakes and clutch linkage.
  2. atch
    atch
    Ain't that the way it goes; if it's not one thing it's another...
  3. saltflats
    saltflats
    from Missouri
    At least it was just an old 409 it wasn't that hard to work on.
  4. atch
    atch
    "just an old 409"
    Most of us would give a testicle for a 409...
  5. Almostdone
    Almostdone
    Ooh baby….my first 2-post lift going into the shop and working on distressed lettering for the doors of a friend’s 53 Power Wagon. Life is good!
    John
    Tim, Stock Racer, Deuces and 12 others like this.
  6. Re-kitting the carbies... Hopefully the end result is less leaking... better jetting and more drivable around town !!!
    Tim, enloe, Deuces and 10 others like this.
  7. pila38
    pila38
    Working on the dash. Got my daughter in the garage today and she welded the new panel in. IMG_5489.jpeg IMG_5517.jpeg IMG_5518.jpeg IMG_5519.jpeg IMG_5520.jpeg IMG_5522.jpeg IMG_5523.jpeg
    neilswheels, Tim, enloe and 25 others like this.
  8. patsurf
    patsurf
    427 sleeper, deathrowdave and pila38 like this.
  9. Greg Rogers
    Greg Rogers
    Good job by your daughter- good to see the younger ones being involved. Boots would be a better shoe choice... Yeeouch!!
    brading, mad mikey and pila38 like this.
  10. pila38
    pila38
    Sometimes you just have to learn the hard way! Just kidding, you’re right, should get her some better foot wear
    chevyfordman likes this.
  11. 51504bat
    51504bat
    Still much better than the sandals you see being worn on some of the YouTube videos of repairs from India or elsewhere:cool:
    427 sleeper and pila38 like this.
  12. atch
    atch
    It should take only once having hot slag inside your sock/shoe to convince you to NEVER do that again. I still catch myself doing it occasionally as "it'll be ok since I only have to stick something together and only weld for a few seconds." I know it'll get me again someday though.
  13. hrm2k
    hrm2k
    KIDS !!!! DONT DO DRUGS !!!! You do stupid things
    For more than 60 years I’ve wanted a metal flake paint job.
    I flaked my 65 V8 Corvair while I had really bad cataracts. I now can see !!! I am so pissed.
    I’ve done some stupid shit in my life, this is one of those times.
    But ……I’m gonna leave the roof and the tail light panel flaked.
    Okie Pete, Deutscher, rod1 and 11 others like this.
  14. 427 sleeper
    427 sleeper
    God Damn... that's alot of flake to get rid of! :eek:
  15. hrm2k
    hrm2k
    When I screw up, it is always in a big way.
    I open the garage door, drive the car out front. Get my tools together, close the garage door……flake problem in the garage solved. Unfortunately, my drive in front of the building looks like a stripper runway :D
  16. 427 sleeper
    427 sleeper
    Welp... you could always have worse things in your driveway... I suppose... :p
    It makes for one hell of a story, though!!! :D
  17. lumpy 63
    lumpy 63
  18. chevy57dude
    chevy57dude
    1. Maryland HAMBers
    @hrm2k - Just make sure it's medically prescribed. The rev did!
    Okie Pete, Deuces, lumpy 63 and 2 others like this.
  19. DDDenny
    Christmas lights:mad:!!!
    427 sleeper and hrm2k like this.
  20. lumpy 63
    lumpy 63
    Had to machine a couple of rings to proerly register the drums on the Winters axles 20241207_123027.jpg
  21. saltflats
    saltflats
    from Missouri
    That's what I did today, wife said I could bring my leg lamp upstairs :D
  22. Christmas party a couple years ago……
  23. saltflats
    saltflats
    from Missouri
    Cleaning parts for TH400 rebuild. I'm feeling like it's time for a beer.
    Tim, Okie Pete, pila38 and 8 others like this.
  24. lumpy 63
    lumpy 63
    Finished up the QC install on the roadster today. Went to fire it up and both carbs started barfing fuel down the throats....this is what happens when you don't drive your shit. Pulled both carb tops off and cleaned the needle and seat assembly's + the squirters. Pulled the plugs cleared and lubed the cylinders and fired it up. Took it for a drive and the QC sounds AWESOME:D. Put about 10 miles on it and parked it in front of the shop... When I came out later I noticed a drip under the rear end, looks like the pinion seal has a small leak. I guess I'll call Winters tomorrow and see what they suggest.
  25. oldiron 440
    oldiron 440
    Indigestion….
    saltflats and lumpy 63 like this.
  26. wilkinson
    wilkinson
    Cool project! I think I wouldn't be able to do something that complicated myself. I would ask Smooth On for help and make sure it is done perfectly. They have the expertise and materials to assist with such a project, ensuring everything is seamless and high-quality. Don't hesitate to reach out to them for guidance and advice on how to execute it flawlessly
  27. mopacltd
    mopacltd
    I don't see Uncle Steve's 55 or the off topic Plymouth. Colin
    lumpy 63 likes this.
  28. saltflats
    saltflats
    from Missouri
    Well made it this far, got all the hard parts in. Now time to build the valve body.
