Customs What am I doing
Discussion in 'The Hokey Ass Message Board' started by JimsF1, Dec 7, 2019.
  1. TrailerTrashToo
    TrailerTrashToo
    Love your truck. Don's Hot Rod Shop, on Stone in Tucson stocks Dzus fasteners.
  2. Dick Stevens
    Dick Stevens
    Dzus fasteners are used where you need to be able to remove a panel and reinstall it quickly, the floorboard isn't the best place to use them, I would recommend using bolts that will hold it down tight and prevent some of those annoying rattles!
  3. PhilA
    PhilA
    1. Hydro Tech
    Definitely. Either that or if you want to curse at yourself a ways down the road (or the next owner) install rivnuts in the floor and put screws or bolts through into them.
    Why? If you've never gone to undo one and it just spins, well, you're missing out on life!
    (Rivnuts are actually pretty good though).
    Phil
  4. My 49 was the old standby 66 chevelle marina blue. Was painted when I got it. 49fordpu.jpg
    kidcampbell71 and loudbang like this.
  5. PoTaToTrUcK
    PoTaToTrUcK
    So here is what I did on my Mercury. Under hood detailed in Calypso Coral, same colour as my father's Boss 429.
    Inside I did the stock colour but removed the gauges, added a Shift-o-guide speedometer and trimmed with a Mercury hood spear. Tremec 5-Speed, disc brakes front and rear, removed the vent glass, power windows, Mustang II and Mercury Big Job hood spears. DSCN1100.JPG DSCN1086.JPG Also removed the ashtray and lengthened the glove box door.
  6. Blue One
    Blue One
    from Alberta
    Rivnuts are awesome when you choose the right style (ribbed) and install them correctly with a good quality tool in the properly sized hole.
    Even then once in a while you will have one that spins loose.
    That's why when I did the removable floor pans and transmission tunnel in my 26 RPU I used all 1/4" steel rivnuts to secure them. Lots of them.
    Then when I was finishing the welding before prep for paint I tack welded each and every one of them on the bottom side.
    After painting I ran a tap through every hole and when I bolted the floor-tunnel in I used stainless bolts liberally coated with never seize.
    I won't have any issues.
    Like I always say, work smart not hard and plan ahead. :D
    Dino 64, JUNK ROD, Halfdozen and 5 others like this.
  7. JimsF1
    JimsF1
    Thanks trash! I'll look Dons up
  8. JimsF1
    JimsF1
    I'm listening Dick! Rattles drive me and the Dog nuts
  9. JimsF1
    JimsF1
    Lol to funny Phil
  10. JimsF1
    JimsF1
    Absolutely beautiful PoTaTo , I would love to see my engine compartment look like that
  11. JimsF1
    JimsF1
    Great tips Blue , sounds solid (and quiet)
  12. JimsF1
    JimsF1
    20191207_152200.jpg 20191207_193736.jpg Well Gents!
    I'm down to lifter and cam shaft removal today, I continue to love this H.A.M.B family for their help and insight. I'll try to get more photos of today's progress. Till then here's a couple.
  13. JimsF1
    JimsF1
    20191207_152149.jpg If you can see where the rust is not that is really how awesome this engine is, still don't know why this was parked after 57 but I don't think it was an engine problem
  14. JimsF1
    JimsF1
    Today's progress, only cam removal left.
  15. JimsF1
    JimsF1
  16. JimsF1
    JimsF1
  17. Wanderlust
    Wanderlust
    Sorry Blue one but your first paragraph drove my filthy little mind right down the rabbit hole, started with ribbed, good quality tool and properly sized hole OMG
    kidcampbell71, Blue One and loudbang like this.
  18. Wanderlust
    Wanderlust
    Hopefully it’s just me and I can be segregated and treated for my affliction
  19. JimsF1
    JimsF1
    Good morning H.A.M.B. Bones
    Here's the up date on the 51F1
    I've taken the disassembled 239 V8 to the Flathead specialist here in Tucson and boy o boy was it cool! this gent which some of you know (a H.A.M.B. Member) is the real deal and like all of you a true good guy wanting to see me succeed with the F1.
    The engine is good as far as we know at this time in unbelievable condition but we'll know more after he boils this thing in the brew. As far as we can see no cracks and one piston bore with rust damage that will force me to bore to a 30 over but we think we'll go 125 based on his inspection after a thorough cleaning.
    I'm now on the search for engine rebuild parts and I am asking if any of you are willing to part with any extras you have sitting around. Is it PC to ask that here or ok with you all to do so?
    Either way again thank you for keeping me motivated be safe and have a great day
    JUNK ROD and Tim like this.
  20. JimsF1
    JimsF1
  21. JimsF1
    JimsF1
    Just joined the H.A.M.B. Family members and gonna put the H.A.M.B. Tag on fire wall any recommendations on that?
    Also any suggestions on which H.A.M.B. Vendors will give a poor old ford owner the best savings on engine rebuilding parts
    JUNK ROD likes this.
  22. Tim
    Tim
    from KCMO
    For rebuild parts I would ask your engine guy? I’m sure he’s got a good recommendation, and then I’d search the list of alliance vendors for their name.
    I know Tim McMaster aka yblockguy builds some snotty flatheads I’d try him as well. Not sure why it’s not letting me tag him maybe I’ve got his user name slightly wrong
  23. loudbang
  24. JimsF1
    JimsF1
    Thanks Tim
    Yes he had suggestions, I was just asking in case some of you fine folks had purchased any gasket sets or bearing set and wanted to clear space in the garage for Christmas presents
  25. JimsF1
    JimsF1
    Thanks Loudbang
    Hombre and loudbang like this.
  26. JimsF1
    JimsF1
    Merry Christmas H.A.M.B.'s
    JUNK ROD, waxhead, charleyw and 2 others like this.
  27. Flathead Youngin'
    Flathead Youngin'
    Keep taking lots of pics and posting them.
    I've have never really wanted a old truck but something has changed. I've got my eye on one locally......it's looking better every day!
  28. I’ve been down the same road as you. My 8BA is .125 over with a Schneider cam. I bought French military crank and rods from So-Cal speed and had it balanced. I got valves, lifters, and Zephyr springs from Reds. It scoots along, but I probably would have gone with a bigger cam if I had it to do over again. Running Edelbrock heads and 4bbl.
    Hombre, kidcampbell71 and loudbang like this.
  29. JimsF1
    JimsF1
    Will do Youngin
  30. JimsF1
    JimsF1
    That's cool, thanks monster48
