So today I went to the local welding supply outlet in this area. They are Esab dealers as well as many others. The rep called the Esab tech line to try to get me a roll of their "easy grind" mig wire. The result was it has been discontinued with no replacement or equivalent item offered or listed. The rep said I may be able to find a dealer who may still have a supply, but he was doubtful.
I bought a spool a month ago from NORCO in Wenatchee, WA. will check tomorrow on availability ..........
NORC which is a NW base company shows 198 lb's of it. You can go to NORCO web site and order it direct. Try using the new part number of ESB130PS43, that should be Easy Grind Mig 025X11#. ESB is a East Coast Company. Hope this helps..............................
