Welding question from a novice -- I need to weld on a brass elbow onto a steel filler tube for my gas tank (so that I can vent the filler tube to the outside of the trunk). Filler tube has been scrubbed clean and blown out, so as to get rid of gas fumes. Question: Can I weld the brass elbow onto/into the filler tube? Can I use my MIG, or do I need to braze it on (w/ brass rod) using O/A tanks? Thanks in advance for responding.
No Mig here!!! You can braze or use silver solder or "sil-fos"(spelling?, combo rod, we use this on several non-ferrus to steel applications) obviously with oxy/acet ....make sure your gas tank is nowhere around!!!!
this is good stuff, used in the AC/R industry.......go to your local hvac dealer and they'll have it....... very similar to sweating two pcs of copper pipe together.......will pass inspection without proper cleaning of mating surfaces, actually i think that is why it was made...... use your acetelyne set...
Brass fittings and common brazing rod melt at about the same temperature which can make things a little tough. Soldering like the guys say looks to be the way to go. A couple of other options: JB Weld it together. No heat required. Why use a brass fitting? You can find a steel fitting that would probably duplicate your brass fitting. Check the Weatherhead fittings stuff at a real parts house. Alternatively, look in a hardware store or an Orchard Supply. They have a wide variety of plain steel - as well as brass - fittings. Keep in mind as well that you can alter fittings to do what you want in many cases. Instead of stacking fittings to go from 3/4" NPT to 1/8" NPT, find a 3/4" NPT plug with hex head, drill and tap for 1/8" NPT. (You may have to check a different brand of plug since the head thickness on some is not as thick as it should be for the 1/8" NPT fitting. It usually is if you get a plumbing supply piece instead of an auto piece.)
I'd just drill a slightly smaller hole and push the hose in a little ways... K.I.S.S..... You could, also, weld on a steel (or stainless) nut or fitting, and use a brake line for your vent. JOE
use steel tubing and braze it, if you can't find steel tubing and have to use the brass use a solder, but not just any solder, use a high strength solder like silver solder typical plumbing or electrical solder might not be strong enough.
