Technical Weld, glue, screw, or other on your hot rod floor panels?
Discussion in 'The Hokey Ass Message Board' started by Almostdone, May 6, 2020.
  1. Almostdone
    Almostdone
    I’m ‘almost done’ with my ‘31 Model A coupe body. I have reprod ( absolute sheet metal) floor panels in front, under, and behind the seat. My question is how to best connect these panels to the car. I was going to simply stitch weld them to the sub frame, but now I’m thinking it might be nice to be able to remove them in the future.
    They fit well. I will use seam sealer at a minimum.
    Thoughts or suggestions?
  2. 41rodderz
    41rodderz
    from Oregon
    If you want them to be removable then all you can do is screw, bolt or use Dzus fasteners . You could Velcro them in but I don’t think you would want that.:D
  3. anthony myrick
    anthony myrick
    I have used these, they rivet in and come in several sizes
    its called a floating anchor nut
    teach'm and Bandit Billy like this.
  4. error404
    error404
    from CA
    I used similar ones that were weld on, (cage nuts) for access panels in the floor of my Willys. I'm a big fan of leaving access where ever possible, makes your life a lot easier in the future when everything is all together and you need to get at something.
    https://www.mcmaster.com/90955a112
    you can probably find them cheaper than McMaster though.
  5. anthony myrick
    anthony myrick
    same here on the weld on
    these come in smaller sizes, even for machine screws
    makes a neat way to fasten small items
    mad mikey likes this.
  6. dartracer
    dartracer
    Mine is welded in with a removable panel for the trans.
  7. 265 X 0.125
    265 X 0.125
    I'll be darned. That's exactly what I've been looking for (to replace rusted off "boxed in nuts" on a mid 60's car). Didn't know they existed. Thanks!
    loudbang and anthony myrick like this.
  8. anthony myrick
    anthony myrick
    weld on style
    loudbang and jimmy six like this.
  9. Almostdone
    Almostdone
    Thanks folks. Weld-in floating anchor nuts it is.
  10. anthony myrick
    anthony myrick
    I bought my last ones from Fastenall.
  11. Rickey Joy
    Rickey Joy
    They are used in airplanes to hold inspection panals on
    Sent from my moto e5 go using The H.A.M.B. mobile app
  12. anthony myrick
    anthony myrick
    We got ours from Aircraft Spruce
    They look great with brass flush squeeze rivets.
