Technical Weatherstripping coming off. How to attach permanently?
Discussion in 'The Hokey Ass Message Board' started by evintho, Apr 20, 2025.
  1. evintho
    evintho
    I applied new door weatherstripping last year and now it's coming off. New weatherstripping from Steele Rubber, I used 3M Super Weatherstrip Adhesive (black) and followed this procedure to the letter......
    Just got the car back from paint and noticed the leading edge of the pass door has come loose! Thought I did everything right. I could try reattaching it again with the 3M stuff but there'll be residue that'd be a pain to remove. The car is now altogether and finished and I just want to reattach the weatherstrip pemanently. I have a bottle of this so I was thinking of just slathering it on the rubber and the door and hoping for the best! What does everyone think?
    https://www.amazon.com/dp/B07D1NZNN8?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
  2. Bandit Billy
    Bandit Billy
    3M weatherstrip adhesive
    alanp561 and sidevalve8ba like this.
  3. 302GMC
    302GMC
    from Idaho
    Did you lay a bead, seat the rubber & pull it up, then wait 15 seconds & attach it ?
    Bandit Billy likes this.
  4. Jagmech
    Jagmech
    Have used liquid nails on some corners/turns where 3m yellow had a little trouble staying in place until set-up. Scuff both, acetone, glue hold in place with small clamps/ clothes pins , 24 hrs.
    rattlecanrods likes this.
  5. Lloyd's paint & glass
    Get a tube of windshield urethane, that'll hold it.
  6. Bandit Billy
    Bandit Billy
    I lay a light bead, smush the rubber against the door, then tape it till dry. To tape it, I tear off a few 6 or 8" strips of inch wide tape, push the center together so it doesn't stick to the weatherstripping, and tightly secure the ends. I made the mistake once, o n c e, of taping across the trunk seal on a Camaro I was prepping for Barret Jackson. Yeah, it tore the weatherstrip when I pulled it lose. I never let the sticky bit touch the weatherstrip since then.
  7. BJR
    BJR
    Before you glue any rubber to a car, clean the mold release agent from the rubber. I use acetone and a clean rag and wipe down the gluing surfaces really good. Then clean the car body where the weatherstrip will glue to. Lay a bead of 3M black weatherstrip cement on the rubber and smooth it out with a spreader. Lay another bead on the body and spread it out also. Wait about 5 or 10 minutes depending on temperature and stick the rubber to the body. Never had the rubber come loose when I do it this way.
  8. 1971BB427
    1971BB427
    from Oregon
    I've never had any luck getting weatherstrip to stick by waiting. It dies very fast, so I use 3M black also, but only apply as much as I can stick in place and tape before it begins to skim over. So sometimes that's a fairly long area like a trunk lid, or fairly short area if it's tougher to get to, and needs taping to keep it in place until it's dry.
    I just had to redo the bottoms of my doors where the weatherstrip didn't hold, and I did maybe 6" then taped, and moved along until the whole edge was done. Then I closed the doors and let it sit overnight. Returned the next day and removed all the tape. I use blue painter's masking tape and it didn't tear any weatherstripping off.
  9. Sorry I am confused. You put the weather strip on then had the car painted? If so I am going to hazard a guess the shop pulled it off to paint as they should have.
    winduptoy and SS327 like this.
  10. evintho
    evintho
    I jambed the car last year then installed the weatherstrip. The exterior was painted last week.
    So again, my question is, will the JB Weld Super Weld hold the weatherstrip permanently? The surfaces are gonna be rough cuz it's too hard to access to clean the old adhesive off.
  11. I don't think a 'Super Glue' type product is viscous enough to fill any low spots (or porosity) that may be on the under-side of the weatherstrip. I would also be fearful it would attack the paint and cause lifting. Trim adhesive or even rubber cement would be a better choice IMHO.
  12. Been using brush on super glue forever. Get the weather strip all in place with it . Then go back and use the black weather strip 3m in the corners.
  13. downlojoe33
    downlojoe33
    Having the same issue with a 6” piece of strip on the rear of my 56 F100 door. Will applying new adhesive over the old work? Because I am not sure how to get the old adhesive off in that short of a space without it becoming a much bigger problem. Following.
  14. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    This is going to sound a little cray cray, but consider SHOE GOO, a shoe repair adhesive. I have used it in several applications where some compliance and flex are required. IMO, a miracle product.
    jimmy959, alanp561 and '28phonebooth like this.
  15. BJR
    BJR
    I believe the main reason weatherstrip doesn't stick, is it is not cleaned with acetone or lacquer thinner first. If this is not done first the glue only sticks to the car body.
    alanp561 likes this.
  16. evintho
    evintho
    I ran over each piece of weatherstripping with lacquer thinner before I applied it.
  17. downlojoe33
    downlojoe33
    Is that something you can only get online?
  18. winduptoy
    winduptoy
    I have had good luck with Loctite 598 black gasket maker...RTV
    also, I find lacquer thinner a little hard on the rubber and use prep solvent, wax and grease remover...
    either way, you need to turn your cleaning towel often or you are just wiping diluted mould release on the next section you are wiping
  19. evintho
    evintho
    UPDATE:
    I used the JB Weld stuff. The dried 3M adhesive that I originally used was smooth so I just applied the JB Weld over it. The rubber stuck immediately so I just closed the door and let it sit overnight. Seems to be holding just fine. Only time will tell.
    tb33anda3rd and '28phonebooth like this.
  20. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    No - generally available at drug and hardware stores.
  21. gimpyshotrods
    gimpyshotrods
    evintho and klleetrucking like this.
