Technical Was Ford planning on going to 5x4.5” in 1948
Discussion in 'The Hokey Ass Message Board' started by el Scotto, Sep 23, 2020.
  1. el Scotto
    el Scotto
    from Tracy, CA
    ...or is this just some kind of owner modification?
    Vehicle is a 1948 Mercury Coupe.
    The original front drums/hub and rear hubs on the banjo have two bolt patterns on them. The studs are in the normal 5x5.5” pattern but both ends also have the small Ford 4.5” bolt pattern as well.
    It seems a little odd for an owner to do the work but not use the holes but I don’t know. Anyone seen this before?
    Sorry for the crappy pictures... the holes did correctly measure out...
    560798D4-7E6F-4F1A-9B14-7EF6D635EC2C.jpeg D9F83A57-05C3-41E5-8DEF-E7B94ECEFFDA.jpeg 1F9C1607-49B2-4233-8E04-2D7035963756.jpeg
  2. 42merc
    42merc
    Modified.
    Ford & Merc's were 5 1/2" thru '48.
    Merc continued 5 1/2" to mid '51. Ford cars went to 4 1/2" in '49.
  3. alchemy
    alchemy
    I’ve got some 40 hubs that someone drilled a second pattern into, then I put studs back into the 5.5” pattern.
    stillrunners likes this.
  4. no55mad
    no55mad
    With the 4.5 bolt circle it's hard to find a rim that will sit properly on the 46 to 48 front hub. Hub has to be machined to cut that lip back more to the center; so the rim center hole will not high center (on the center of the hub tapered casting).
