Technical Voltmeter!
Discussion in 'The Hokey Ass Message Board' started by 57 Fargo, Jan 10, 2021.
  1. Anyone know of a voltmeter that the needle comes from the top of the gauge? My google is letting me down?
  2. Turn it upside down....
    Deuces, VANDENPLAS, mad mikey and 3 others like this.
  3. Then it’ll read backwards to the rest of my gauges...not sure if that’ll play with my mind...
  4. blowby
    blowby
    from Nicasio Ca
  5. Exactly like that one...thanks!!
    VANDENPLAS likes this.
  6. jimmy six
    jimmy six
    As long as it’s not a Lucas...... I’m good.
    seb fontana likes this.
  7. brading
    brading
    You ole boys have got something about Lucas haven't you. Had Lucas for a lot of my life and never heard of a problem that was out of the ordinary. Reckon you must have got Chinese shit marked up as Lucas that side of the water.
    Ned Ludd and VANDENPLAS like this.
  8. Done enough electrical troubleshooting in British sports cars to understand why Lucas has been called the prince of darkness. One MG had 3 positions on the lights: dim, flicker, and off.
  9. Ordered a sunpro voltmeter that is virtually identical, my plan is to disassemble the new gauge and put it in the Fargo where the ammeter is.
    I’m really just looking for an indicator that the charging system is working.
    loudbang, fauj, j-jock and 5 others like this.
  10. BigDogSS
    BigDogSS
    from SoCal
    I had a company convert my ammeter to a voltmeter. Did not change face, but knew 12 volts was right about 12 o'clock.
  11. Budget36
    Budget36
    Who did the work?
    I plan to start re-wiring my ‘57 this spring, and would like to do that as well
  12. I’m curious as well, I’m just cheap...I think it should be relatively simple, I have a spare gauge set to take apart first
  13. Well, Lucas is found on the majority of British vehicles so to you it's 'normal'. We know better... LOL. I had a Jaguar monkey on my back for a while, and while I love those cars, the ever-continuing electrical issues finally wore me down. I may own another one some day, but the first order of business will be to completely rewire it minus all Lucas parts...
    Q. Why do the British drink warm beer?
    A. Lucas refrigerators....
    loudbang, Boneyard51, fauj and 7 others like this.
  14. WDobos
    WDobos
    Lucas, the prince of darkness !
    loudbang and chevy57dude like this.
  15. Mr48chev
  16. Fabulous50's
    Fabulous50's
    from Maine
    You could use a red light to illuminate the ammeter as an idiot light. But the needle wouldnt move.
    I'm assuming you have an alternator which supports an idiot light.
  17. Actually, Lucas gauges are quite good. That is how you know exactly how your system is falling apart.
    Bob
  18. Yea, I thought of a light as well. We will see how this goes first!
  19. My other plan was a 60 amp ammeter guts I the stock gauge. Then I have to change some wiring. The voltmeter is simpler...
  20. Fortunateson
    Fortunateson
    Most of the troubles with the Lucas stuff is either ground/earth connections not tight or, as in my case, previous owner(s) screwing around with the wiring and buggering things up.
  21. 55blacktie
    55blacktie
    What's the difference between Smiths and Lucas?
  22. Budget36
    Budget36
    Guess he’s keeping it a secret...
  23. Must be...tough crowd here lately...
  24. BigDogSS
    BigDogSS
    from SoCal
    loudbang, 57 Fargo and Budget36 like this.
  25. brading
    brading
    These were two totally different companies. Smiths were more a instrument company and they made heaters. Lucas were more into generators, starters, distributors, lighting and cabling and that sort of thing.
    j-jock likes this.
  26. brading
    brading
    That's a good idea think I might see if one of the companies over here can do that.
  27. Ebbsspeed
    Ebbsspeed
    The Ammeter is simpler. You can set it up to handle more current by running a shunt, which is simply a wire in parallel with the ammeter. If the resistance of the shunt is the same as your 30 amp ammeter, then 30 indicated on the ammeter is actually 60.
    Ah, the good old days of the HAMB.
  28. e1956v
    e1956v
    Alliance Vendor
    loudbang and BJR like this.
  29. Yea, the volt meter is just a new wire for it, ammeter involves undoing harnesses at this point, I will admit I hadn’t thought of a shunt.
    The more I think about this the more I like the idea...
