I have a '28 Ford with an engine which I'm hoping is original but doubt. I see the VIN number on the engine. However, the plate on the firewall is unreadable. Is there anywhere on the chassis that may have on VIN stamped on it?
http://www.jalopyjournal.com/forum/showthread.php?t=259686 Typical of many posts on here. Try search. Also: http://idisk.mac.com/forever4/Public/pages/assemblyplantbodynumbers.htm
The VIN # is stamped into the chassis right at the left side forward cab mount, to see it the body has to be removed. From underneath you can look up and you'll see a cab mounting bracket riveted to the outside of the frame, the cab will have 2 bolts going thru this bracket (there is another single bolt coming thru foreward of this accessable at the firewall), the vin# will be stamped into the frame rail right at this bracket. The stamping is on top of the frame rail and the body has to be removed to read it.
