Technical Vertex Magneto SBC
Discussion in 'Traditional Hot Rods' started by Jamoke, Dec 19, 2020.
  1. Jamoke
    Jamoke
    What is a good nostalgic drag racing performance single plane intake manifold that I could run with a Vertex Magneto I am thinking you cannot run a tunnel ram with a Magneto
  2. dreracecar
    dreracecar
    from so-cal
    Plenty of SBC's running TRs and a Vertex Magneto
    427 sleeper likes this.
  3. If a HEI will work with an intake manifold your wanting to use, a Vertex magniro should clear with ease.
    Hollywood-East likes this.
  4. Jamoke
    Jamoke
    But you would have to run a sideways linkage to clear tunnel ram
  5. AngleDrive
    AngleDrive
    from Florida
    Works with a 4-71 also
    51box, Elcohaulic and triumph 1 like this.
  6. DDDenny
    Whatever it takes to get there!
  7. 427 sleeper
    427 sleeper
    Not necessarily. You can run Holley 4160's inline with 1" spacers underneath, or run AFB's inline with no spacers. If you're wanting to run 4150's, you'd have to run them sideway's anyhow.
  8. 19Eddy30
    19Eddy30
    from VA
    Any single carb intake will work (sbc)
    & most Tunnel ram ,& 3-71 to 8-71.
    Your challenge will be Learning how to set up (Mag) & learning to start a engine with a Mag,
  9. dreracecar
    dreracecar
    from so-cal
    They sell a Relay kit for the magneto to work with a standard ignition key, If there is advanced timing built into the mag, starting is no different than a dist. If the mag timing is locked out and you are running a lot of compression , then there could be starting issues that would require a mag kill switch starting system
  10. 19Eddy30
    19Eddy30
    from VA
    No fancy electronics needed.
    Most inexperience will try to start with Mag On , then say Mags are Junk !!
    All thats required is to have mag to Ground off (-), spin the motor with starter 2 seconds or so , then Flip the Kill switch to On .. if all tuned & adjusted correctly .
