VDO Speedo Shake on my 1928 Abone
Discussion in 'The Hokey Ass Message Board' started by Oldmanolds, Feb 28, 2014.
  1. Oldmanolds
    Oldmanolds
    I replaced a broken cable on my VDO speedometer. Ever since the swap my needle shakes at any speed I run. Any suggestions on what it might be? I was hoping to get it fixed and road tested before the predicted foot of snow arrives. I really don't want to start part swapping if I can isolate what it might be and have at it.:confused:
  2. did you lube the new cable?
  3. Oldmanolds
    Oldmanolds
    Nope. Think that's it? What should I lube it with?
  4. olscrounger
    olscrounger
    Lube it with the graphite stuff that Napa sells and make sure the ends are tight on the speedo and trans (by hand-not crazy tight) with no tight bends
  5. scrap metal 48
    scrap metal 48
    It also may be a tad to long if you replaced just the cable and not the housing...
  6. ROADSTER1927
    ROADSTER1927
    You need to lube it and the inner cable maybe a little to long regardless if you bought an assembly or not. So you can loosen the top or bottom nut some and see if that helps. Gary
  7. Oldmanolds
    Oldmanolds
    How would I know the right length? Tried all other suggestions and still have that shaking.
  8. If you loosen the housing ends like Roadster mentioned and it stops or changes then its too long. Whe its a hair too long, the cable rubs on the inside of the housing and bids causing that bouncing.
