Valve guide clearance?
Discussion in 'The Hokey Ass Message Board' started by steel rebel, Apr 1, 2013.
  1. steel rebel
    steel rebel
    How tight should valve guides be? I'm redoing a set of '55 Cadillac heads with almost zero miles on them since new guides because of a crack in the head. I've cleaned them up and are trying to put them back together and the valves are tight. Do the guides open up when the engine worms up or will they start to stick?
    Thanks Gary
  2. Common valve stem clearances are: .001-003 for intake, .002-.004 for exhaust. The valves should move freely in the guides. Make sure everything is clean when you assemble the head.
    Who put the guides in? Valve guides are pressed into the heads and then finished reamed to the recommended size.
    Bob
  3. Mr48chev
    Make sure that the end of the stems are trued up so that they don't have any edges sticking out to hang up on the guides. Dressed right they will have a barely noticable bevel on the edge of the tip.
  4. steel rebel
    steel rebel
    That might be part of the problem. Once I get them in they seem to glide smoothly.
  5. Please don't make them too tight! They will stick and cause lots of problems. They should feel free in your hand but not sloppy. better loose than tight.
    as said earlier .0015 to .003 is OK but I don't imagine you have a gauge to check this.
  6. Mad Mouse
    Mad Mouse
    If you drove in new guides, they must be reamed to a specific size. If this was not done, they will be way tight.
  7. hoop98
    hoop98
    from Texas
    Some Specs:
  8. steel rebel
    steel rebel
    Thanks
    Pretty close clearance half to one thousands clearance. Seems like if they move smoothly it's probably alright.
