For sale is a V8-60 flathead. This is not a tin side but full cast iron, so probably 1939. I've had it in my collection for a few years now, and I got it from an estate where it came out of a race boat. Engine turns over by hand. Cylinder walls look good, and I don't see any stuck valves. I see two cracks, one of them the cylinder has already been sleeved, the other one looks like it will need a sleeve. It is ported and relieved, and has a rare Harmon and Collins Full race cam. Has duel point ignition. Factory aluminum heads and intake that have been polished. It includes the oil pan but modifications will need to be made because of the larger crank gear. It originally had a custom oil pan with larger sump. It has a chain drive gear on the crank. No carb, fuel pump, water pumps, flywheel. You don't get the opportunity to buy a race v8-60 everyday. Even if you don't have that perfect car to put it in yet, it looks right at home in your man cave and it is a great conversation starter! Contact Amanda or Dimitri 951 907 0867/951 970 0007 $800
