I would like to get a v shape brake line splitter.I thought I seen them in a catalog once but it might be a figment of my imagination,the old brain ain't what it used to be.By v shaped I mean that the lines are 45 degrees not 90. Any body know were I can get one?
If you want the 45 degree layout for reasons of neatness or utility that's one thing. If you are concerned about the fluid having to turn corners, the flow rates are low enough that it's not an issue. I remember seeing high pressure hydraulic fitting with a 45 split, but I can't remember seeing one on a car. Could you make this work? http://www.holley.com/972059ERL.asp
sorry seperate posts but my mind is old today......... there are many oem hoses sold with the Y type block built in to go from frame to rear axle
Ha Ha Ha believe it or not I found it in a JC WHITNEY CATALOG it is listed as a Bendix Brake Line, Product # BENBR46952
