There are a few posts on You Tube on the engines Ardema and Braun have built. Pete will put a overhead cam on anything including a Flathead Ford.
I've seen Ford Engineering T prototype engines from the era. Anything you can think of was tried back then. A few examples - OHC cam driven by bevel gears - 5-cylinder version - the infamous "X" motor; two pairs of 4 cylinders arranged in radial fashion
Ford was working on the X8 as early as 1920; as seen in the cartoon above some were water cooled designs. None were marketable.
This is not as unusual compared to the others here, but this is my chrome head Lincoln V12. I got it here on the HAMB a few years ago. I still have to get some things squared away before I can tinker with it. My 39 Zephyr is still in storage as well.
Packard straight 12. I understand they built only one or two of these as a prototype and decided against it.
Have y'all seen the Jay Leno YouTube (might have been a My Classic car) where he is hot rodding a Stanley steemer, they were on their fifth or six rendition of different baffles in the boiler trying to keep the pressure up so they could go faster longer. Hot rodding is universal.
The one-piece aluminum crankcase for the Duesenberg straight-12 engine. One of the largest aluminum forgings made at the time and weighed 365 lb (166 kg).
Is that a V12 or a 4V DOHC V6? Either way it is an interesting example of using the engine as a stressed chassis member.
Interesting that one cam turns clockwise and the other cam turns counterclockwise. I wonder if the cams were the same but able to be swapped end-for-end? That would have simplified things. FE SOHC
From Mac's Motor City Garage: "Drag racers burned midnight oil tackling the Cammer’s issues, including the mile-long timing chain. Working with Harvey Crane of Crane Cams and P&S Machine, the always creative Pete Robinson produced this gear drive system. Note the additional gear on the left bank, allowing a right-hand camshaft to be used on both cylinder heads." I'm still trying to wrap my head around the gear train. How do you wind up with 2:1 crank to cam ratio with the different tooth counts left & right?
How do you wind up with 2:1 crank to cam ratio with the different tooth counts left & right?[/QUOTE] The different tooth count cancels out. First it goes 1:2 from big gear to little gear. Then back down 2:1 from little gear to big gear.
