Does this look familiar to anyone? My stock 63 rambler died last fall and now it's running. Pretty sure I lost spark. Anyone know what I have here? Sent from my iPhone using The H.A.M.B. mobile app
Has to be over ten years minimum. With the random dying I thought I might want to have a replacement on hand. Maybe I should find the vendor on the HAMB? I'm sure there's no one in Canada selling these? Sent from my iPhone using The H.A.M.B. mobile app
Thanks guys. I'll see if I can message Mr hotroddon. Sent from my iPhone using The H.A.M.B. mobile app
Stock breaker plate will be in there, you should be able to remove the Petronix components and add points and condenser for your Rambler application. When you take the electronics out you will need to add a new wire from the coil to points. If your cap and rotor are on good shape run them.
I do like points. Have them in the flathead. This was in the car when I got it ten years ago. Sent from my iPhone using The H.A.M.B. mobile app
Cap and rotor are good. Will the coil still be ok? It's a 1.5 ohm aftermarket coil. Sent from my iPhone using The H.A.M.B. mobile app
Wow. My local Napa store has the points and condenser in stock. Maybe I'll run those for the weekend. Hope the coil will work ok. Sent from my iPhone using The H.A.M.B. mobile app
You will either need a 3 ohm coil or a 1.5 ohm ballast resistor Sent from my XT1650 using H.A.M.B. mobile app
Thanks. But the pertronix uses a 1.5 without ballast? How much are replacements? Sent from my iPhone using The H.A.M.B. mobile app
The trigger looks like a 1181. They are about $80/USD. A ballast resistor is ~$6-$18/USD. A NAPA 1.5-ohm ballast resistor is: ECH ICR108.
Nobody mentioned the reluctor wheel. Fairly certain that something went in place of the cam that bumps the points. Yes? No? Tape?
No. The reluctor wheel on this model is bolted on under the rotor, on the same screws that hold the rotor down: You can see it as the black ring, under the brown rotor. See how the fasteners come up from below, and not down from the top? The point cam is still there, just going along for the ride.
Yep. It's all there except the little screw. Thanks again guys. Really appreciate the advise. Sent from my iPhone using The H.A.M.B. mobile app
