Projects uncle Charlie's hot rod model A projects
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Feb 19, 2025.
  1. Uncle Charlie [aka super slacker] started working on another model A project, well actually two, before he even finished his model T hot rod.
    build here; https://www.jalopyjournal.com/forum/threads/t-body-on-a-frame.1278530/
    he was given a model A chassis and was told it had a bad rear axle, he got it running and restored the brakes, mounted a cowl but found , not only was the rear noisy but the clutch chattered and the motor leaked oil out the rear main badly. IMG_9838.jpg
    bchctybob, GuyW, winduptoy and 10 others like this.
  2. we found another chassis and another cowl which Charlie got running and it ran well so he swopped the brakes over from chassis number 1. the plan is to keep scrounging parts for chassis number one while he builds number two. IMG_1983.jpg
    here is Charlie robbing hinges off number one chassis
    bchctybob, winduptoy, TFoch and 9 others like this.
  3. plan with chassis number two is to build a pickup cab. Charlie had a set of doors from a 4dr model A so we built a subframe , adapted the front doors to the cowl and cut down the rear doors IMG_1981.jpg
    bchctybob, EVL401, winduptoy and 6 others like this.
  4. I cut a new windshield header , we welded in some steel and installed the visor and fitted a windshield frame. IMG_1978.jpg
    bchctybob, winduptoy, TFoch and 6 others like this.
  5. tubman
    tubman
    If this is as good as the last "Uncle Charley" thread, I'm all in!:)
    winduptoy, Stogy and tb33anda3rd like this.
  6. rusty valley
    rusty valley
    expensive jeep tires on there !
  7. Charlie has an eye for making junk look good
    winduptoy, Stogy, loudbang and 2 others like this.
  8. it should be , but the slacker is slowing down
  9. he was sent those by mistake and the tire company gave them to him real cheap so they didn't have to take them back.
    most everything on these chassis were free or close to free. mostly other peoples discards.
    winduptoy, Stogy, loudbang and 4 others like this.
  10. Maybe he can find and axle and transfer case and make it 4wd to go with those NDTs!
  11. :D
    winduptoy and Stogy like this.
  12. I cut and fabricated a couple pieces for the rear floor and back of cab. when I get back IMG_2107.jpg IMG_2109.jpg
  13. AVater
    AVater
    1. Connecticut HAMB'ers
    You guys do great work skills as well as showing resourcefulness and awesome creativity!
  14. thank you, Pete, just having fun
    winduptoy, Stogy and AVater like this.
  15. pieces I made in place. and a side shot of the 4 dr doors cut down to make the B pillar of the cab. the back of the cab will be a couple inches bigger than a stock pickup and the doors will be flush. Back of the cab will more closely follow the lines of a 28-29 pickup cab with a "twist".
  16. took the remainder of the 4 door rear doors and a 2 door rear window garnish that Charlie had back to my shop. thought I could make a rear window for the truck cab. image6.jpeg image9.jpeg
    bchctybob, Stogy, winduptoy and 5 others like this.
  17. cut the back and upper side of the rear doors window opening , and the pieces I cut off the front side of the rear door window openings. I cut them to match the 2 door garnish molding image7.jpeg image5.jpeg image4.jpeg
    bchctybob, Stogy, winduptoy and 6 others like this.
  18. this will get welded into what ever I make the rear of the cab from.
  19. spent the afternoon helping the slacker. he cut off what was left of the welded on fender braces and we beat the front frame horns straight. image6.jpeg image5.jpeg
    bchctybob, Stogy, winduptoy and 9 others like this.
  20. we made up the top supports that connected the top of the windshield post to the B pillar. then connected the back edge of them together with a roof support beam I took from a 65 suburban parts truck.
    bchctybob, Stogy, winduptoy and 7 others like this.
  21. we then mocked up and measured for the back side of the cab. we hung the window to get a visual on the position of it. image2.jpeg
    bchctybob, Stogy, winduptoy and 15 others like this.
    Charlie put the new junction block in and a battery shut off switch in
    bchctybob, Stogy, winduptoy and 3 others like this.
  23. we put a middle crossmember in the roof
    then Charlie decided we should chop it, we decided a 3" chop would be perfect. we removed the doors, cut off the top
  25. we then cut the windshield bottom off, removed 3" and welded it up.
    Charlie got tired as we started cutting the doors so we called it a day. image7.jpeg
