Technical U-joint caps fitting
Discussion in 'The Hokey Ass Message Board' started by topher5150, Feb 5, 2025.
  1. topher5150
    topher5150
    How tight are the u-joint caps supposed to be in the yoke?
    I got a new set of joints and the od of the caps is about the same as the id of the yoke.
  2. Should be a light press fit at a minimum. If the cap is loose in the driveshaft, you either have the wrong u-joint or somebody has honed/stretched the holes.
    Truckdoctor Andy and lostone like this.
  3. RodStRace
    RodStRace
    What U-joint, what yoke?
    Most of the full circle ones are a slight interference fit, but the ones with snap rings or clips aren't quite as tight. If it's a diff yoke with caps, they are usually able to seat with hand pressure.
    BTW, a difference of a thou (0.001) is an interference fit, "about" isn't close enough.
    deathrowdave likes this.
  4. topher5150
    topher5150
    I tried a couple taps with a hammer but decided against it. The holes in the slip yoke were a little crusty even after cleaning them out it's still tight. Haven't tried the diff or the driveshaft yet
    Slip yoke ID 1.061, cap OD 1.063
  5. should not have to be forced in. sounds like another poorly made new part.....it seems to be the norm. take the micrometer down to the store and measure a few different. brands.....
    1940Willys likes this.
  6. deathrowdave
    deathrowdave
    from NKy
    You have the best advice , something isn’t correct , keep looking for the right stuff
  7. You might try using a brake cylinder hone to clean up the u-joint bores. Don't get carried away.
    topher5150 and Truckdoctor Andy like this.
  8. 2OLD2FAST
    2OLD2FAST
    from illinois
    Hard to describe but whether it's the bench vice , u-joint press or a 3# hammer with a wood block , I've always driven them in ...
    427 sleeper likes this.
  9. Happydaze
    Happydaze
    A reasonable blow with a soft faced hammer is what you need.
    Talking about into the yoke in the rear end where the u bolt / saddle retains the cup. Its a very snug fit. A wrong sized cup can look and feel that it's correct until you realise how good a fit it has to be. Don't ask me how I learned this!
    Chris
  10. arse_sidewards
    arse_sidewards
    from Central MA
    Two thou interference sounds just about perfect.
    There needs to be interference otherwise the caps can spin in the yoke under high load and sometimes eject the clips.
    Installing caps should be a "small hammer" job or an easy job for a ball joint press or a 6" bench vise. If you're able to put the caps in by hand or with a little tapping with the handle end of a ratchet then that's too loose and you should tack weld the caps to prevent spinning. If you're using the big hammer or hydraulic press then something else is probably wrong.
  11. Budget36
    Budget36
    I wouldn’t hone the hole in the joint to fit a particular cap, what will happen next time you replace it?
    But I’ve always had to use force on the vice handle.
    Never liked the idea of a hammer, I’ve had a needle or two come off, then have to press it out again. Seems a hammer might magnify that issue?
    And soft rubber mallet? That would be a new one on me, I’d like to see that in action.
    I’d clean the hole out with a small wire brush, a steel one, shine it up and as mentioned, check for burrs.
