Hot Rods Tunnel ram distributor clearance
Discussion in 'The Hokey Ass Message Board' started by dstangl, Apr 3, 2014.
  1. dstangl
    dstangl
    from central MN
    Well I finally got the carbs rebuilt for my weiand tunnel ram and went too install it everything was looking good till I went to put my GM HEI distributor back in and it hits the back of the manifold. Grinding the back of the manifold seems like a bad idea and I don't know if that would be enough anyway. does anyone have any creative solutions or suggestions that wont cost hundreds I know a brand new MSD setup would fix it but well...$$$
    this is going on a 350 chevy in a 46 chevy truck
  2. Small body distributor needed. The old points type that Big-Foot suggested can be found cheap and with a simple electronic conversion you are in for under $100. You will need a remote coil, it won't be built in like the HEI has.
  3. fiftiescat
    fiftiescat
    from NY
    MSD makes a "small diameter" distributor just for this reason. The reliability is worth the scratch. The next best thing is a points distributor with a pertonix kit like stated above. You'll always regret grinding that manifold.
  4. terryble
    terryble
    from canada
    Is it a very old dual carb manifold? I took a Weiand dual 4 barrel tunnel ram off a SBC that had been driving with HEI a few years ago just to salvage the manifold and sold it.
  5. Hotrodbuilderny
    Hotrodbuilderny
    If budget is really a problem, just put a point distributor in.They were run like that for years,you can always upgrade to Petronix later on.
  6. GMC BUBBA
    GMC BUBBA
    Small case delco rebuilt with pertronix , cap and rotor ready to run ....$300
    Bubbas
  7. captmullette
    captmullette
    procomp, has what u need and reasonable........
  8. dstangl
    dstangl
    from central MN
    Thanks for all the info so far I'd have to buy a used distributor, pertronix kit, and new cap would cost as much as a ready to run distributor from summit or MSD....anybody use those? pro comp was also mentioned? I don't want to go back to points partially because it's old and mostly because I have no experience with it
  9. oldolds
    oldolds
    Dual Point! the only old school way to go! They can be dialed in for the r.p.m's a small block with 2 4's can make!
  10. verno30
    verno30
    ProComp distributors are shit.......
    I use some of their stuff since I am cheap. Don't skimp on electronics. Let's see the situation unfold..........
    Going down the highway at 65.
    vroom....vroom......vroom......pop bang...fuck.....
    "hey cool ride mister....what's wrong"
    "oh, I have a sweet ride but deceided to save a couple bucks."
    "see ya at the show."
    "probably not......my odd ball, Made in China by a 12 year old girl distributor is shot."
    28 Ford PU likes this.
  11. Joliet Jake
    Joliet Jake
    from Jax, FL
    I had the same issue, two engines running tunnel rams. I use Mallory Unilites.
    Screw points and condensers, that's for,well the other guys.
  12. exactly!! :D
