Technical Transmission tailshaft part identified?
Discussion in 'The Hokey Ass Message Board' started by vintage_car, Jan 30, 2017.
  1. vintage_car
    vintage_car
    Purchased a rebuilt transmission turbo400 and it looks like something should be covering this?
  2. Hnstray
    Hnstray
    from Quincy, IL
    It is where the the speedometer drive plugs into the transmission.
    Ray
    timmy2times likes this.
  3. 24riverview
    24riverview
    What Ray said and that looks like a turbo 350.
  4. 1930 A
    1930 A
    Or it could be a 700R4. either way that's where the speedometer gear housing goes
  5. mgtstumpy
    mgtstumpy
    You need these plus a hold down bolt to drive your speedo
    Just the 'C' retainer. That looks to be a TH350 governor cap as it is on driver's side of case.and not a TH400.
    A TH400 has 4 x hold down bolts and is on passenger side of case
    TH350
    TH400
  6. mgtstumpy
    mgtstumpy
    Check what you got, this is 700R (4 speed - Overdrive) as 350 and 400 are 3 speed. If it is a 700R you may need different rear gears and to set you TV cable correctly or you won't have a transmission for very long.
  7. squirrel
    note that the OP posted a picture of a TH350, the tail is shorter than a 700, although it looks very similar.
    I hope you didn't pay TH400 money for that transmission
