I bought a working 400 trans from a guy (i saw it actually motivate the truck prior to buying it), and when i got it in my truck i noticed it didnt have park. Is this a cog inside the pan problem, or something hydrolic? Seached but didnt see anything on this. Thanks
28pontiac Without the linkage hooked up and sycling through it won't work. budd Can i do this without going behind the pump, ya know from in the pan. Or is it a major fix? SinisterCustom same question for you then. Can i get that done from the bottom? Thanks guys.
i have snaped a few park pins off but i have never fixed one, i usely just use the e-brake, maybe if you have to pull the valvebody you should slip a shift kit into it.
Hip, Yea, you can just cycle the lever by hand. IIRC push the top all the way towards the bell housing. Then give the output shaft a turn, it should click and lock it up. You can also look at it (I think) by pulling the tail shaft housing. I'll go home tonight and look at one I have sitting out and give you a picture. Thom
Parking "pawl", its a small lever/pin that could have broken by shifting the car in park before a standstill.
