Hi All, I have a th350 that at times does not go into gear. If you give it a little gas it slips into gear...? Any thoughts as to where to start with diagnosing? Thanks, Mack
...and burnt forward clutches, and it probably has a worn out stator support, and some worn out drums, and the pump is worn out. In other words, it's a "good used" transmission that needs a complete rebuild.
Any time I have had a T350 that was slow to go into gear it was not long until it would not go into gear at all. Maybe it is just low on fluid but that is about as likely as me being president, yes possible but no probable.
My daily has been doing the same thing for about a year (178,000 miles) and was worse in the winter. I just shift between D and R a few times and let it warm up on cold days. This time of year, no problem and it otherwise works fine. Still I know it won't be long until...........
I had a 64 rambler station wagon I bought years ago. Got it running drove it for about a week and coming up my mountain drive way one day, it just shot transmission fluid out the dip stick and emptied most of the fluid. I towed it up to the shop, and dropped the trans pan and replaced the gasket and filter and filled it back up. Never had a problem after that. I am pretty sure it was a clogged filter.Bruce.
Thanks Bruce! That's the first thing I'm going to do is clean it out. It did sit quite awhile at some point. I have only had it on the road a handful if times now.
Hey Guys, Ok, I dropped the pan and the filter was clean as could be. So, I asked at the parts counter and they said to try the vacuum modulator.
Now..... I've broken the tab for the retaining ring that holds the modulator in place.... It's always something huh?
Shifter adjustment? Mine just did something similar, wouldn't go into reverse, move shifter a little more and it engaged. Would slam into drive, adjusted it a little bit and works smoothly now.
You broke the case? Forward clutch seals or excessive clutch wear ..Low /rev doesn't apply in D , 1st
Ok, vacc modulator has seemed to make the issue better.... Looks like a rebuild is in the near future though.... Thanks All!!
