The stock 6 cyl in my '54 is tired. I have the option of purchasing an '89 SBF and was wondering what the best (read cheapest) tranny option may be. I don't think the original 3 spd could work because there is no provision for a mount on the tailshaft. At this point I am open to all options because I know that I will to have to fab in mounts for the engine and tranny, and it will be a minor miracle if there is no need to build a new drive shaft. So, what should I look for? 3 speed, 4 speed, 5 speed, or auto? thanks, Conor
c4 would probably be the cheapest/easiest , AOD would take more work to hook up the linkage and probably a more expensive tranny to rebuild but it depends if you want overdrive
ive got a 56 and i have a 89 motor out of a mustang. i just picked up a c4 out of a junked car and everything looks like its gunna work great
Conor, This is what I had done to my 55'. 13k since August 03. http://www.ford-trucks.com/user_gallery/session.php?&formstate=editalbum&albumid=5196
i got a c4 behind my 84 302. a c6 would work out too, since you are gonna have to fab a trans mount and driveshaft to go that route. i had a aftermkt trans mount in mine when i got it, otherwise i woulda just fabricated one, there is nothin to them.
I don't think C6 will work. I did AOD in a '66 PU and had to cut and raise hump about 3". C6 about same size. Go with C4.
Yes the best auto option would be the c-4.........c-6 would be good but like phil1934 said check the floor pan clerance..........Now for manuals 4 speed in good shape is going to be hard to find........(around my place anyways) so look for toploader 3 speed(RAN tag trans has 2.99 first gear)....easier to find and cheap........under 50 bucks usualy.........also if you want over drive a 5 speed would be good..........getting very easy to find and not very big, most have shifter made onto it so measure to see if line up properly.........so best two options would be c-4 or 5 speed...
Thanks for the replies. If I go that route, it sounds like the C4 option is best. However the sacreligious 350/350 combo at a can't pass up price may be in my future, too. Conor
im going with a t-5 in my 1955..behind a 351 windsor.t-5s are not the cheapest route but you can get a t-5 from 300-500 bucks. being able to shift and overdrive...priceless...make sure its world class.
