Tranny for a 56 Pontiac
Discussion in 'The Hokey Ass Message Board' started by R.Reynolds, Oct 18, 2011.
  1. R.Reynolds
    R.Reynolds
    from florida
    im wanting to put an over drive tranny in my 56 pontiac...any ideas?
  2. 55chieftain
    55chieftain
    Wilcap and Bentsens make an adapter for the 55-60 blocks for newer trans pattern.
  3. X2 on the adaptors. Perhaps 55Chieftan can give you some ideas on fitment, too. If not, Pontiac Years Tech Forum is a good place for advice. http://performanceyears.com/ I was looking to do the same with my '63 Catalina. The 700R4 was large enough that major floorpan surgery was necessary. But, the 2004R wud fit with a few taps with a BMFH.
  4. R.Reynolds
    R.Reynolds
    from florida
    awsome thanks....
  5. poncho55
    poncho55
    I just got my Wilcap adapter today. Assembling all of the components - got the Mopar starter, modifying the 2 barrel carb to accept TV and throttle linkage, looking into a new plastic display to move from RD1D2D3N to PRNDD3D2D1, thinking about a switch for the lock up into overdrive.... Should have everything ready for install before the spring arrives as I just put the car away. $575 for the adapter, $65 for the starter, $225 for the 200 4R core, $700 for it to be rebuilt with Torque converter... in for a penny..
  6. 55yak
    55yak
    I'm putting a Chevy 700 R-4 in my 55 with a Bendtsens adapter kit, but I sure need advice on building mounts. Keep me posted on your project.
  7. poncho55
    poncho55
    Will do. Mine will start in the spring again as I just put her in storage for the winter.
  8. rusty A
    rusty A
    You never said what kind of engine you are run. My friend put a T5 with a 6 cylinder in his 56 and it bolted right up. Just a thought.
  9. 55chieftain
    55chieftain
    Maybe in a Canadian Pontiac eh
  10. I'd lean towards a 200R4 in a Pontiac only because the 700 is long and may not clear the frame X crossmember. They're fairly wide with the bottom offset to the right a bit, too.
    That said, if the stock hydramatic transmission is working, you don't need the overdrive. It's already a 4-speed trans and the gears in the back are likely around a 3.08 and it should cruise all day at 65.
  11. GassersGarage
    GassersGarage
    I just installed the Wilcap Adapter in my '63 Grand Prix. The plate had to be modified and the spacer had to be milled, plus it took 2 weeks to get. Bendsten had the kit in stock.
  12. 55yak
    55yak
    I'm putting a 700 R-4 into my 55 Chieftain with a Bendtson adapter to a 57 347 and I thought building mounts would be my big problem. Now that I have an empty trans mission case for mock up, I find out it is one hell of a bad (read tight) fit in that tunnel. I'm looking at major surgery here and I'm beginning to feel I am in over my head. Has anyone else put one of these 700's in a tri-year Pontiac?
  13. ClassicDriver
    ClassicDriver
    I realize this is a very old thread...
    55yak - Did you get the 700 R-4 in you 55 Chieftain? If you got in, did you have to do a bunch of surgery on the tunnel?
