Technical Torque tube drive
Discussion in 'Traditional Hot Rods' started by metaldave, Nov 2, 2014.
  1. metaldave
    metaldave
    from michigan
    I am using a 37 Ford rear axle in my car. Do I need to put the speedo gear, thrust washer, and c-clip on the front of my drive shaft if I am not using the speedo drive ? Thanks in advance. Dave miller
  2. Pretty sure all that stuff is what holds the bearing in place.
  3. 28rpu
    28rpu
    Rich B is correct.
  4. Bruce Lancaster
    Bruce Lancaster
    Holds it all together, provides the thrust bearing to position everything.
  5. 4-port Riley
    4-port Riley
    you can leave the driven gear off if you want.
