torque thrust lug nuts
Discussion in 'The Hokey Ass Message Board' started by two to many, Jun 3, 2010.
  1. two to many
    two to many
    from Cadott WI
    I have a set of early torque thrust wheels to put on my 63 nova,Im nut sure what style lug nut to run shank style or closed acorn style.
    thanks in advance for any ideas
    Todd
  2. Automotive Stud
    Automotive Stud
    The modern ones use a bulge seat lug nut but I think the early ones might use the mag style with the shank that goes into the wheel. Easiest way to tell, if the mag style will fit through the hole that's what you need you can't have the wheel loose on the lugs.
  3. brandon
    brandon
    what brand....? i had some d's from the mid 90's that were shank style , some from the later 90's that were acorn style ...et's that took a acorn with a small shank ....post a pic if possible......
  4. two to many
    two to many
    from Cadott WI
    mine are american racing torque thrust, I would late seventies era,just guessing
    thanks
    Todd
