Hey guys, anyone have the specs needed for torque on the bolts of a Mustang II? The A frames, ball joints etc. It's under a 41 Ford coupe. I believe Heidts parts. Not sure of the cross member maker. It's a friend who is relying on another guy to take care of these things. Just the other guy has not gotten to it even though he's promised to. I'd like to help so this ride can get out of the garage. Thanks for any help. Dom
Upper A-arm shaft, thru '78 95-120 ft lbs, '79-80 120-140 ft lbs. Ball joint 75 ft lbs then tighten as necessary to align cotter pin hole. Lower control arm, crossmember bolt, 95-120 ft lbs., strut bolts, 40-60 ft lbs.,ball joint, 75-90 f t ls. Hope this helps to get another one on the road. jerry
