Technical The smallest physical dimension production V8?
Discussion in 'The Hokey Ass Message Board' started by BamaMav, Aug 28, 2020.
  1. FrozenMerc
    FrozenMerc
    Evinrude made a 3.6 liter 2-Stroke V8 for outboard motors in the late 80's and Early 90's. Very compact by nature. The motor held outboard powered top speed records up until the past few years. I know at least one ended up in a Volvo Drag Car. All extra space was taken up by the expansion chamber pipes. Not sure if it would be smaller than V8-60 though.
  2. Beanscoot
    Beanscoot
    The Evinrude at least was made in the USA. It works out to 220 cu in., and most likely makes a lot more power than a V8-60.
    From a bit of internet reading it appears that this engine was even increased to a 244 cu in. capacity.
  3. BamaMav
    BamaMav
    from Berry, AL
    Kinda off the path of the thread. Didn't see many boat motors come factory in cars, possible exception would be the Taurus SVO, but seen a lot of car motors in boats....
  4. Hnstray
    Hnstray
    from Quincy, IL
    The Ford SHO V8 you refer to was designed for sure and, I believe, built by Yamaha. Sort of like the same era Corvette ZL 1 (or ZR 1 ...always get that confused) was built by Outboard Marine Corporation for Chevrolet/GM.
    But you are correct that it would be a good contender in this thread, in all categories, overall size, weight and performance. Good call!
    Ray
  5. outagas1961
    outagas1961
    if your not dead set on a v-8 the G M 60 deg v-6 is tiny and can make good power. i believe largest displacement was 3.4 ltr
