Technical The smallest physical dimension production V8?
Discussion in 'The Hokey Ass Message Board' started by BamaMav, Aug 28, 2020.
  1. 51504bat
    51504bat
    Started out as a 2.6 in the Capri and then went to 2.8. Ford used them in Mustang II's and Rangers for a while IIRC. I was going to put one in an OT MGTD but never got around to it. Very narrow and compact.
  2. BamaMav
    BamaMav
    from Berry, AL
    I knew it was a 2. Something, I was just off by .2, lol. You’re right, MII, Rangers, and Explorers all used them in various displacements. Tough little engines.
  3. 51504bat
    51504bat
    Sold some parts off a core engine I had years ago to a guy in Canada. I guess there is somewhat of a following for these V-6's. He wanted a set of heads but all I had were CA heads from what he told me and not very desirable. OK, back to small V-8's not V-6's.
  4. greybeard360
    greybeard360
    No one has mentioned the AMC V8. It is narrower than a 221-302 Ford, shorter than a 265-400 SBC. They are 290-401 in the same package and make good smooth HP. The 304-360 are easy to find also.
    dare-to-be-different and AHotRod like this.
  5. Rusty O'Toole
    Rusty O'Toole
    From memory, Buick 215 = 320 lbs, Ford 289 = 450lbs, Chev 283 = 540 lbs, Dodge 318 = 580 lbs. Anyone know a smaller, lighter V8 than the Buick?
  6. Hnstray
    Hnstray
    from Quincy, IL
    That’s true, but not a shallow as it sounds. The Buick engines of that era V8 & V6, had deep skirt blocks.....the pan rail was well below the crank centerline.
    Ray
  7. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Its actually very similar to what Chevy did on (Hamb unmentionable) its successor to the venerable smallblock.
  8. ekimneirbo
    ekimneirbo
    from Brooks Ky
    The Buick successor Rover has a pretty nice intake system that you can remove the cover from and run fuel injection stacks on an older Buick.......or keep it on the larger displacement Rover and put Buick valve covers on it.
    Make a heck of a nice engine with powder coated and polished valve covers and headers. You can run just a carb on them too.
  9. KenC
    KenC
    Sorta like the ‘other’ y-block.
  10. pitman
    pitman
    ekimneirbo, that is gorgeous!
    300 lbs, 280 CU!
  11. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Its probably closer to 320 lbs but there are things that can lighten it some like mini starter and lighter brackets and alternator. Was gonna put one in an airplane once upon a time.......
  12. ekimneirbo
    ekimneirbo
    from Brooks Ky
    gnichols, Hnstray and pitman like this.
  13. pitman
    pitman
    Helium blanket...in the oil pan!
    Thanks for the info.
    ekimneirbo likes this.
  14. bigaadams
    bigaadams
    from Georgia
    just throw in any ole engine you want..it is the Flux Capacitor that makes it all work....
  15. I plugged the table that @1946caddy provided into a spreadsheet, then summed each engine's (length+width+height)
    The engine with the smallest cumulative dimension was... The SBC short water pump, at 76" total.
    The biggest: Ford SOHC 427 at 100":eek:
    The Buick/Olds 215 was 81"
    A few others:
    BBC long water pump: 92"
    Ford Flathead: 83"
    Buick 425: 90.5"
    Yeah- I'm a nerd and it's a slow day at work.:rolleyes:
    Ned Ludd and lothiandon1940 like this.
  16. Wilson V4... 196cu, 300hp. Installed in midgets and hotrods dscn0748_orig.jpg
    Ned Ludd likes this.
  17. Blue One
    Blue One
    from Alberta
    o_O Reading comprehension problems?
    The title of the thread specifies V8 engines and production engines.
    So you then decide to post a V4 that’s obviously 4 cylinders off and definitely not a production engine. :rolleyes:
    Way to go :D
  18. Not production but has been installed in passenger cars. Wicked midget engine. Smooth & powerful. 68EC7392-6392-4CAD-A7B4-B1BF0ED7F108.jpeg
  19. Not really, but thanks for your concern. Good to see you're back on your meds. It happens to be half a production SBC that's been modified slightly. Some would say that motor has been hotrodded. I keep forgetting that the NEW HAMB is all about the restoring and restoration of old cars, with hotrodding and the creativity it inspires now occupying the proverbial backseat. Having read (and comprehended) the complete thread, I noticed the mention of V6's (clearly lacking 2 cylinders). Since the thread had swerved off topic a bit, a V4 seemed the next logical progression. Now really who, besides you that is, can really argue with some good old hotrod creativity.
  20. oldsman41
    oldsman41
    Is everyone forgetting the sunbeam tiger had a ford 260cu in it had room to spare
  22. Couldn't find a picture on my phone with the hood open ,but both are flathead v8 60hp . No cutting of the frame or firewall .
    dsiddons likes this.
  23. seb fontana
    seb fontana
    from ct
  24. You can get these as small as 5.5 oz.......
  25. Mr48chev
    I'd say That the little 215 Buick or Land Rover version V8 is going to be just about the smallest outside physical dimension V8 that you are going to come up with that is somewhat readily available.
    Flathead V8 60 engines are indeed very small physically.
    Some of the suggested engines may be small cubic inch displacement wise but are big physically and weigh a ton. The little 221 Ford is still the exact same size physically as a 302.
    26 T Ford RPU likes this.
  26. Blue One
    Blue One
    from Alberta
    :D Yes it veered off topic. And you helped with a 4 cylinder push :D
    Hot rod creativity is always good.
    Since you seem keen on meds perhaps it’s time for yours :D
  27. BamaMav
    BamaMav
    from Berry, AL
    Neat chart, you need to post it with all the production V8 engines you can think of. Show the dimensions, length, width, and height, with standard issue factory parts, I.E. short and long water pumps, carb intakes, could also throw in average weight if known. Give you something to do on a slow day at work!:D:D:D
    grumpy65 likes this.
  28. grumpy65
    grumpy65
    Yes, a little bit of a tangent, but very cool nonetheless.
    Let's relax Blue One, you're turning red.
    Normal transmission resuming imminently...................................;)
    KiWinUS likes this.
