Hot Rods THE INDUCTION THREAD
Discussion in 'The Hokey Ass Message Board' started by mad mikey, Dec 9, 2016.
  1. KoolKat-57
    KoolKat-57
    from Dublin, OH
    And now for the mundane....... 1957 Pontiac Tri Power on the motor they came on. latest shots 022.JPG
    1958 392 Chrysler Imperial Hemi Offy Manifold Carter AFB's in my Deuce Roadster latest shots 025.JPG
  2. 28dreyer
    28dreyer
    from Minnesota
    IMGP8846.JPG IMGP5689.JPG e-bay 008.jpg P1011205.JPG P1011206.JPG P1011207.JPG Here's clearer photos of the flat head Studebaker Rich posted above...
    ...and the Worlds only DOHC Chevrolet as far as we know. Two updraft Winfields. Notice the throttle linkage shaft traversing internally in the manifold fabrication, and the throttle arms down to the carbs and the actuating arm on the end. This engine was built in 1960, raced, shelved until recently, has been revamped, and is currently running on the test stand.
  3. Fordors
    Fordors
    That DOHC Chevy is outstanding, and the only way to describe the throttle linkage is exceptional! I'm looking at this on my i Phone right now, but I think the finish on the head, etc. is cool too. Looks like scraped ways as on a machine tool, right?
  4. 28dreyer
    28dreyer
    from Minnesota
    Correct, you are seeing flaking or flowering as is/was done on machine tool ways. More attractive to my way of thinking than the more common, but rare, "engine turning". Both the intake manifold, and both cam carrier housings and attached front bearing carriers are done this way.
    If you look closely on the Studebaker pictures, you can see another of his throttle shafts that comes through the firewall supported by a ball bearing in the firewall left of and near the bottom of the barrel valve, parallel to the lower fins on the engine side cover. The bushed bracket with grease fitting on the block of the rigidly mounted engine is to the right and not visible in the photo. The item just to the lower right corner of the barrel valve and just below the blue fuel fitting is the throttle arm from that shaft up to the jack shaft that operates each throttle runner, individually with adjustable links for flow balance, in addition to the adjustable link to the barrel valve.
    loudbang and mad mikey like this.
  5. Paul
    Paul
    Editor
  6. Paul
    Paul
    Editor
  7. I always liked this style of Weiand tunnel ram, just looks more "mechanical"
  8. I agree swade41, one of the best looking tunnel rams, looks great polished.
  9. saltflats
    saltflats
    from Missouri
  10. Some really great stuff especially the home custom machined stuff. Keep the post coming.
  11. RRichFox
    RRichFox
    1943 Ford V8 tank motor.
    mad mikey likes this.
  12. alfin32
    alfin32
    from Essex, Ma.
  13. cheap-n-dirty
    cheap-n-dirty
    V6 Buick, with the only Hilborn injection manifold made.
  14. Rattle rod
    Rattle rod
    Edelbrock X-1 with six stromberg 97's 20160525_162454.jpg 20160525_205002.jpg
    Jet96, cruiserjohn76, loner2 and 7 others like this.
  16. falcongeorge
    falcongeorge
    from BC
    Man, I've always wanted one.
    quicksilverart46 likes this.
  17. saltflats
    saltflats
    from Missouri
    Would be nice to hear all the tuning woes and succuss storys with some of these.
  18. johnnymac1
    johnnymac1
    250 with 3 x 1 glass bowl Holley's IMG_20160727_171811188_HDR.jpg IMG_20160727_171841683.jpg
    brigrat, desotot, mgtstumpy and 2 others like this.
  19. Yes! I would like to see some tuning discussion , thats also why I created the thread. Post it up, the good , bad, ugly, whatever you like.
  20. classiccarjack
    classiccarjack
    Those glass bowls look amazing! Good way to check float level!
    Sent from my XT1585 using The H.A.M.B. mobile app
    belyea_david likes this.
  21. mgtstumpy
    mgtstumpy
  22. johnnymac1
    johnnymac1
    My center carb is primary, front and rear are secondaries, progressive linkage, I got the center carb adjusted so I could set idle and timing, broke the motor in and have 3 or 4 hours run time on it, Linkage took a little thought , but went much easier than I thought it would. Front and rear will need to be fine tuned to my power band, and rpm. I will get any bugs worked out in the spring. The worst part about float level adjustment is every time I have to pull a bowl I get a little nervous, if I crack a small logo bowl I have others, if I crack a big logo bowl, it takes for ever to find them. Motor will idle nicely at 750, good response, I had to block off some of the vacuum ports for the old Ford distributor advance system. No real horror stories yet
  23. saltflats
    saltflats
    from Missouri
    This is my 4X2 on someones truck after I sold it a a swap meet. 20151017_131012.jpg
  24. HiHelix
    HiHelix
  25. HiHelix
    HiHelix
  26. falcongeorge
    falcongeorge
    from BC
    Throttle body intake?
  27. saltflats
    saltflats
    from Missouri
    Yes this was the cross fire lower.
    falcongeorge likes this.
  28. Not mine, but wish it was. Another CROWER 8 port. RONS fuel injection is re popping these, most likely big $$$$. DSCN2182.jpg DSCN2183.jpg
