Hot Rods The HAMB 327 thread index
Discussion in 'The Hokey Ass Message Board' started by DDDenny, Dec 21, 2017.
  1. DDDenny
    Ultimately, I'd like to see people respond to some of the other 327 threads in the index, just to let them see the light of day, the 327 has been quiet too long.
    Granted, some were requested info type threads that the original poster had walked away from but I'm sure people can find something in them that they can relate to, learn from, add to, etc.
    chryslerfan55, Deuces and Stogy like this.
  2. Stogy
    Stogy
    Huge Database and growing of shared History...Cool Indeed...And Search is your best friend...;)
    chryslerfan55 and Deuces like this.
  3. UNCLECHET
    UNCLECHET
    Here's a picture of a bone stock 1965 L-79 327 in my Corvette. I took it out for a romp last Wednesday. Still pulls, sounds, and feels like nothing else! Love it! I had a grin the rest of the night. Actually I still do! Oh yeah, it's missing the chrome covers over the spark plug wires. L79.jpg
    chryslerfan55, Hank37, Deuces and 3 others like this.
  4. Fitnessguy
    Fitnessguy
    Good pic of the ol jalopy Sir!
  5. A 69 327 came out of a wagon was originally a 2bbl powerglide. I installed new rings bearings a 30-30 cam. Extensively reworked 57 heads and C4B intake ngines 007.JPG . I need to get it installed in the 55 in my avatar.
  6. 54BOMB
    54BOMB
    Large journal 327 , this block is .030 , four bolt main , 6 inch scat rods , forged speedpro L79 style pistons , 2.02 heads , Schneider hydraulic cam , mid 60’s Weiand , holley 650 dp. Long tube headers that might be a little too big.
    If I were to do it again I would have picked more compression, cause it sounds really good. C043FB20-9F39-4D86-9E76-83ADD1E3C7F5.jpeg DC481791-7BCF-4085-A0F2-BBDD9F80DC9F.jpeg A17BEA81-18CE-4D9C-8865-646F08AAB444.jpeg Next steps are different aluminum heads .
  7. Hollywood-East
    Hollywood-East
    Here's one under boost @ 6300 rpm... Econo build, 68 large journal, standard bore, new hyper pistons, 3/8 arp on stock rods, 882 heads, new HD springs, lathe turned Locks (key!) Comp cams nos/blower cam... Had about a grand in the long block said/done, only sent out rods/pistons, Vertex, dyers, two carters, everything else done in house... Sold truck . haven't found anything lately to put it in... Second one in pic. Is a Small journal soon to be injected(mechanical) NCM_2582.JPG
  8. Chucky
    Chucky
    I have these in storage.
  9. Pass The Torch
    Pass The Torch
  10. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Nice girdles.......
    Deuces, Stogy and 402BOSSMAN like this.
  11. 48stude
    48stude
    My 66 .040 over 327 in my 29 roadster
    6inarow, chryslerfan55, rod1 and 6 others like this.
  12. 1964 Corvette .030 over hoping to run fuel injection in a 1949 Chevy Fleetline. [​IMG]
  13. blue 49
    blue 49
    from Iowa
  14. My 64 Corvette had a 327 in it when I bought it. It was said the car had had 14 different engines in it before I bought it, including a big block and the front cross member was notched to clear a big block lower pulley. I have no idea what was done to the engine except the seller, a buddy of my brother-in-laws said it was a 350 hp 327. Ran really strong with a muncie 4 speed and a 4.10 posi rear gear. One day I changed the 600 carb out for a 900 Holley 3 barrel and it REALLY ran hard then! I was blown away...loved that engine. 64vette1972.jpg
    chryslerfan55, Deuces and UNCLECHET like this.
  15. nugget32
    nugget32
    65, 327, 2.02 heads, crane cam, 650 holley, Sanderson headers. Screenshot_20191215-081717_Photos.jpeg
    Sent from my SM-A102U using The H.A.M.B. mobile app
  16. The other 327 in the garage right before I put it back into my O/T 68 Camaro where it belongs since Chevy put it there originally, lol. Bottom end is still L30 spec, so flat tops and cast bottom end. Comp 30/30 grind, 69 Z/28 Intake, 4150 Holley, the 68 only heads with no accessory holes and temp sender outlet. The thing just rips and loves the rpm.
    chryslerfan55, Deuces, LowKat and 2 others like this.
  17. Here's the 327 in my 40 coupe. I love 327's, they have a sound all their own.
    Mick
  18. A '64 Small Journal on my engine stand.
  19. Nalusurfer
    Nalusurfer
    Hey guys,
    Got directed over here by DDDenny.
    Getting ready to put intake on my old 68 327 block and and curious about possible hp numbers. This is a motor I bought with a old v drive boat in the early 90's. I've had it and knew I always wanted to build a 327.
    Bored .60 over as it sat for extended amount of time. Finally cleaned up at 60.
    Forged steel crank polished. Entire rotating assembly balanced. 462 camel heads 2.02/1.60. 1.6 Roller rockers. All oil galleys have been cleaned and enlarged for better oil flow.
    Stock resized rods
    9.875:1 compression.
    Lunatic voodoo 701 cam (256/262).
    Edelbrock rpm intake with Holley 650 vaccuum 2ndaries.
    1 5/8" long tube headers in 44 Flowmasters.
    Not a crazy build but a nice shop truck motor.
    Looking at possible hp numbers for this motors.
    Behind it will be a Muncie m21 and Ford 9" with 3.55 Posi.
    I'm guessing 325-375hp???
    Any guesses???
    Thanksgiving
    (Denny, FYI, I'm in Grants Pass )
  20. DDDenny
    Isn't that in the State of Jefferson!:p
    By the way, do you know John Boerste in Roseburg?
  21. Pass The Torch
    Pass The Torch
    I’ll bite. ‘65 with Sportsman heads, roller rockers, Weiand intake, points (for now), and a few Cal Custom goodies.
    chryslerfan55, Deuces and 30tudor like this.
  22. DDDenny
    Deuces likes this.
  23. Dave G in Gansevoort
    from Upstate NY
    20201001_170319.jpg Old mangy 327-250 hp 68 truck engine, never apart, might stillrun. I've had it for 15 or so years. Will be using it (maybe) once the chassis its sitting in is finished. Got a 327 small journal block, that might get used instead with a 283 steel crank. 462 heads either way, whichever one gets built/used. I've used many years ago, but the best was a 365 hp fitted block, assembled with Stahl & Assoc. crank, 492 angle plug heads, factory short track cam 754, 1st design Tarantula w/750 double pumper, Hooker headers, Mallory Double Life ignition, Z28 oiling system. Put it in a 67 SS Chevelle (I hate pig blocks, every garbage truck used to have them back in the day). Why I didn't loose my license with that car, or worse, I don't know...
    26 T Ford RPU, elgringo71 and Deuces like this.
  24. Dave G in Gansevoort
    from Upstate NY
    Bringing this back up. Old mangy is going to the engine shop soon. Hopefully the 462 heads will be usable. Got an Edelbrock Torker (the original model) and a 650 dual feed Holley for it.
    Shooting for 330 hp. I'm not crazy any more. I can do all of the damage I can handle with that much power!
    Deuces likes this.
  25. DDDenny
    Any news Dave?
    Deuces likes this.
  26. Dave G in Gansevoort
    from Upstate NY
    No news. Things got postponed due to dropping the front spring mount and spring on my left foot a while ago. Still need to send the weight jacker to jebbesson as he might use it on his 50s tube frame sports rod. After what it did to me I don't want it in my shop!
    Thanks for the reminder tho. I'll have to call Jack Boyd this week and get started on the 327.
    Deuces likes this.
  27. Dave G in Gansevoort
    from Upstate NY
    Just an update to bring this thread back up.
    Old mangy is down to a short block. DSCN1452.JPG And RATS! It's got a cast crank...
    Oh well, moving on
    Deuces likes this.
  28. Dave G in Gansevoort
    from Upstate NY
    News flash! Old mangy is apart, ready to go to the engine shop. It and it's slightly older brother, a 66 327-300 hp block, and a 283 forged crank, are going to have their day at the engine spa! If everything checks out with both, I'm going to have 2 short blocks to choose from. Now to decide which one gets the new heads, and which one gets the 462 castings.
    Deuces likes this.
  29. Back in April for my birthday, I bought this 327. Guy was pulling it out of his Camaro for one them modern swap. It is a oddball 68/early 69 large journal 327. When I went and looked at it, instantly recognized the head markings and bought the motor without much negotiation. The heads are 69 186 Z/28 pieces, 2.02 valves, have had some heavy port work, new screw in studs, new rockers and springs, new valves, etc. Heads alone were worth what I paid for the long block. Block is a fresh rebuild as well, fresh hone marks and no ridge. Bored 40 over and looking to be a cast bottom end on the crank and pistons. The main issue with the motor was 2 lobes on the cam were flat. So gonna flush the block and do a mild rebuild and most likely stick it my C10 pickup.
    Deuces likes this.
  30. Dave G in Gansevoort
    from Upstate NY
    Nice!
    Deuces likes this.
