Technical The Case of the Hundred Dollar SBC
Discussion in 'The Hokey Ass Message Board' started by blowby, Sep 22, 2019.
  1. blowby
    blowby
    from Nicasio Ca
    Yesterday while picking up lumber across the bay I also grabbed this as a potential replacement for my tired mill. Supposedly rebuilt, obviously in race trim as evidenced by the yellow oil pan and valve cover wing nuts, although the two barrel is a little misleading. Victim of an LS swap, seller said it came in the car and he never even ran it.
    The flex plate, starter, fuel and water pumps, valve and timing covers are new so that probably covers my hundred right there. Who knows, cam went flat on break in, cracked something or other, rattle can rebuild? Place your bets, gonna blow it apart today. Appears to be a lo po
    Surfcityrocker, swade41, Tim and 2 others like this.
  2. Heck, a guy can easily blow $100 on a bad date... I think the risk:reward on this is agreeable. On this Sunday, here's hoping the gods of internal combustion are smiling down on you!
    Party On
  3. A Boner
    A Boner
    I hope your good luck continues.....I'm thinking it will.
    blowby and loudbang like this.
  4. Someone took the time to either scrape off or mask the exhaust ports. Good sign?
    283john, loudbang and Humboldt Cat like this.
  5. Run a compression check. crank it over without spark plugs enuf to see if it build oil pressue. and if everything is ok. Fire it up.
  6. Fordors
    Fordors
    If it was original to an ‘82 Blazer it would be a 305. Not the best for a performance build, but nevertheless you got a lot of stuff for $100.
    The heads look correct for that era, can you give the casting number for the block? Or even better the suffix letters at the front or the block.
  7. oldiron 440
    oldiron 440
    Could be a pot of gold or wooden nickels........
  8. blowby
    blowby
    from Nicasio Ca
    Thought about running it on the stand..carbon on the valves and piston tops, not fresh. Probably cheap insurance to pull it down, might be just a rattle can rebuild, though the freeze plugs are fresh brass.
    Could be a 305..
  9. MeanGene427
    MeanGene427
    from Napa
    427 sleeper, blowby and loudbang like this.
  10. Humboldt Cat
    Humboldt Cat
    from Eureka, CA
    What's the 6 or 7-digit stamp on the back upper deck o the block? Just curious
    Sent from my SM-G930R4 using The H.A.M.B. mobile app
  11. flamedabone
    flamedabone
    Yellow oil pan and valve cover wing nuts = full race. Might also be Vette motor.
    Unless there is a rod sticking out of the block, it is definitely worth 100 bucks.
    Nice score, -Abone.
  12. Doublepumper
    Doublepumper
    Isn't the V for Flint factory? Last four, 9800 Target Master....?
    loudbang and kidcampbell71 like this.
  13. blowby
    blowby
    from Nicasio Ca
    Casting number hard to read. Looks like 14016379
  14. BJR
    BJR
    Or a $100 date could blow you!:D
  15. Doublepumper
    Doublepumper
    That casting number would be a '78-'85 350.
    loudbang and blowby like this.
  16. blowby
    blowby
    from Nicasio Ca
    Thanks, glad it's a 350. Yep, 4.000 bore. Definitely not fresh. No ridge though, and some faint hone marks. Guides tight on the two valves I checked. Some lifter wear. Are those 4 relief pistons stock stuff? Thin steel shim head gaskets. Looks like pretty low compression.
    Probably pull the timing cover, pan and go from there.
  17. Ebbsspeed
    Ebbsspeed
    Looks like one of those cylinders had some moisture in it. Is it light surface rust?
    Old wolf and loudbang like this.
  18. chevy57dude
    chevy57dude
    Yep. Corvette engine.
    Seriously, good score.
    swade41, 61Cruiser and loudbang like this.
  19. Jalopy Joker
    Jalopy Joker
    a good number of years ago had a '65 Chevy Nova SS with a tired 350 - spotted an ad in a throw away advertising news paper : 327 Chevy Rebuilt $300 - was first to call #, and is was not too far away - called a couple of guys to meet me at the address and help load in my family station wagon - struck gold! - was a fresh rebuild by a local big name engine machine shop, with receipts - built to factory specs for 365 HP, with new cam, valves, pistons, etc !! right place at the right time - Nova flew like a bat out of Hell with it - had 350 trans beefed up to go behind it - really needed positraction, because would pull sideways from a dead stop
  20. 427 sleeper
    427 sleeper
    If that's ALL you go home with, you WIN!!!! HAHAHA!!!!
  21. ... yep. Targetmaster 350. "Doublepumper" for the win. Good job.
    Congrats' ... Blowby, prolly' a 4 bolt main coming.
  22. blowby
    blowby
    from Nicasio Ca
    Yeah one pot on the other side too. Looks like rainwater, nothing serious.
    Targetmaster then eh? Thanks DP. Well, good enough for my needs. It will get the Weiand huffer that's on my tired 305 now. The one thing I'd like to do is fit a decent cam.
    Thanks for the replies.
  23. choptop40
    choptop40
    Good score on that one...Squirrel on here is a whiz at engines...He gets motors running that are left for dead only replacing what's necessary...
    pitman and loudbang like this.
  24. big duece
    big duece
    from kansas
    Good night of drinking would have exceeded that amount back in the day, thanks to some lush friends. Nothing to show for it now, but faint blurry memories. Is it a 4 bolt main block?
    a boner and loudbang like this.
  25. Speed Gems
    Speed Gems
    Chrome valve covers and a 2 BBL manifold say "circle Track" engine to me. Probably a Targetmaster crate motor for one of the lower classes like pure stock especialy with the exaust manifolds.
    EDIT: What casting # are the heads?
  26. tubman
    tubman
    Aren't they all?:rolleyes:
  27. Ah... Another SBC goes the way of the flathead. o_O
    RICH B, Deuces, jaw22w and 2 others like this.
  28. Mr48chev
    A bit of clean up, a rering kit with rings, bearings and gasket plus a cam and lifters an a timing set and you are in business. Cam, lifters and timing set will probably be the spendy part of the deal.
    I've got to laugh at some of the guys wild ass assumptions though.
  29. Baumi
    Baumi
    image.jpeg I'd say you got a pretty decent engine for your 100 bucks.
    I picked up an old 283 yesterday. It was cheap too , but it used to be inhabited at one point.... I have never seen a push rod rusted out, hahahaha
    alanp561, tractorguy, Deuces and 3 others like this.
  30. nunattax
    nunattax
    rat or mouse motor?
    alanp561, Baumi, Deuces and 5 others like this.
