Technical The $3 Banjo Housing Seal Install Tool
Discussion in 'Traditional Hot Rods' started by fourspd2quad, Apr 27, 2020.
  1. fourspd2quad
    fourspd2quad
    It's just a guess on the cost, most of us probably have this hardware already.
    While researching how to install my banjo axle seals I came across some info online
    saying there was a special tool with a long shaft you could buy to drive them home from the wide end of the housing. While I started poking around my shop looking for a way to replicate this I came up with this idea. Rather than bang them in from the inside why don't I draw them in from the outside. This is what I came up with. For all that I know this is an already known method but if not here goes.
    I took a 5/8 bolt, 2 washers and a nut and slipped one washer on the bolt.
    I then wrapped some painters tape around the bolt to mimic the I.D. of the seal. This helps to position the seal and keep it concentric to the bolt shaft.
    Then I lubed up the tape with some bearing grease, slipped on the seal and lubed up the seal O.D. also.
    With my axle housing fixed in a vice I slid this assembly into the axle shaft and fished out the threaded end on the opposite side.
    I then added the second washer and nut and spun it down flush to the axle end. Tightening the nut I could slowly begin feeling the seal draw into the pilot, you can feel when it finds home when the wrench comes to a dead stop.
    Sure beats buying a fancy tool that would hardly get used. Besides I think it is a better method as opposed to beating on the seal.
    Thanks for reading! Stay safe.
  2. acme30
    acme30
    from Australia
    Cool and inventive tip thanks for sharing
  3. Good start for a Tech-Week. Been ages i believe.
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    I thought the dark red coating on the outside of a seal was a sealant to be installed dry ,wouldn't greasing it negate its effectiveness ? Just curious ...
  5. fourspd2quad
    fourspd2quad
    You could very well be right but my guess is that just about all of it got removed by the press fit.
  6. flatheadpete
    flatheadpete
    from Burton, MI
    Smart! I love this kinda stuff.
  7. Something I got into several years back. I found some replacement seals for that job actually didn't fit the Axle shaft properly. Part number was a cross over but not right. The I.D. of the seals were large enough they didn't fit snug on the shaft. Hope you did a test fit. Gear lube on new brake shoes really sucks, almost as bad as taking things apart to replace new seals.
    David Gersic likes this.
