Technical The 283 that STILL won't run right
Discussion in 'Traditional Hot Rods' started by thompsonwayne1, Sep 27, 2014.
  1. thompsonwayne1
    thompsonwayne1
    Got it to run better and better but still not right.Finally pulled the valve covers off and ran it at an idle. All the push rods are moving all the rocker arms and opening all the valves except cylinder #2 . The very front rocker arm is moving, but barely. If all the others move a half inch this one moves 1/8 " or less.
    WTF ? Bad lifter ? flat cam? It's a completely stock 283. Now what do I do?
    Thanks
  2. WOW, running on 7 cylinders. Don't know what year your 283 is, but it was not uncommon for camshafts to go bad, for certain in the late 60's and early 70's.
  3. CGkidd
    CGkidd
    Sounds like a bad cam lobe, bad lifter or bent push rod.
  4. MrMike
    MrMike
    You should be able to hear a bad hydraulic lifter, without seeing it sure sounds like a cam lobe rounded off,
  5. 40fordtudor
    40fordtudor
  6. Same problems I had with my Vette. Cam lobe went flat after running fine for over a year.
  7. thompsonwayne1
    thompsonwayne1
    So, I'll pull the intake off, take the rocker arm loose, remove the lifter and maybe put a wood dowel in where the lifter went and see how much lift I get?
    It's a 1963 engine checking by the engine number, I have no idea what the history is.
    If I have to change the cam, once I remove all the lifters does it just pull out?
    If the cam is flat where did all that metal go? into the oil?
  8. CGkidd
    CGkidd
    Unfortunately the metal shaving are in the oil. Hopefully your filter caught most of it. When you pull timing cover I would also pull the pan and give it a good cleaning.
  9. slammed
    slammed
    Yes on removing the lifter's 1st. Pick a cam carefully, one that suits your driving habits for this ride. A broad range ) off idle-5,000 RPM would be ideal.
  10. indyjps
    indyjps
    Double check you rocker stud height with a straight edge layed across all of them, if the stud pulled out partially it can act like a wiped cam lobe. Easy to check before swapping a cam. Sounds like you have not swapped a cam before, be sure to find TDC, top dead center, and make sure your timing tab is correct before tearing it apart.
    343w, verno30, 56don and 1 other person like this.
  11. elba
    elba
    Put a 327, 350 horse hyd cam in it. You will like the sound !
  12. Engine man
    Engine man
    from Wisconsin
    If you have a dial indicator available, measure the lift at the top outer edge of the lifter on the bad one and a few others.
    You also need to remove the mechanical fuel pump before you remove the cam. You have to hold the cam up slightly to work it through the bearings. A handle or long bolt in the end of the cam provides leverage. If it is the original cam and lifters, the lifters could be difficult to remove. They get varnish built up and the bottom might be peened slightly but they will come out. There is a slide hammer tool available.
  13. If you drop the pan to clean it out you should check and maybe replace the oil pump, the cam and lifter crap should have been caught at the filter but only after its passed through the pump. JW
  14. Now what do I do?
    you get to whistle the flat cam blues tune ?
    Should be a pretty straight forward procedure swapping it out. Best thing in the world for a rookie is a manual by "Motors" - fuck the ones at the parts store. Every single thing you need to know about a cam swap is in there except picking a new one.
  15. falcongeorge
    falcongeorge
    from BC
    before you run out and buy a cam, re-read post #10.
  16. CGkidd
    CGkidd
    Concure with all of the above
  17. 302GMC
    302GMC
    from Idaho
    Be aware if the cam has lobes worn out, the rest of the engine has similar wear.
  18. 40fordtudor
    40fordtudor
    Did that with Rhodes lifters---then I loved the sound.
  19. thompsonwayne1
    thompsonwayne1
    I'll check the stud height, and the pushrod too, thanks for the info about the mechanical fuel pump. Not sure what I'll do. Never swapped a cam. The rest of the engines condition ? Who knows? Compression numbers are all over the place, #8 cylinder is 100 pounds.
    Good thing is it's a roadster couldn't have an engine more exposed and easy to work on.
    It's a winter project. I think I'll pull the plug wire off and enjoy the rest of the summer on 7 cylinders. Just took a 200 mile trip with this flat cam before I discovered it. I can get a complete totally rebuilt 283 with lots of new parts for 2K delivered. Lots more horsepower. That will give my noisy 39 Ford tranny even more to complain about.
    Boy, we're sure lucky money grows on trees.
    Thanks for all the info.
  20. A pulled up stud is noisy, just like a rocker out of adjustment.
    But it won't hurt to check anyway.
    Your compression ---
    Last thread you said you were going to add some oil to the cylinders and retest, then report back.
    Did you retest and what were the results ?
    If you need a new engine and can't do the internal work then you'll need to do what works best for you. If you want to get dirty and have your fingerprints inside that engine there's a few options that are pretty cheap. That's up to you.
  21. blackrat40
    blackrat40
    I believe you will need to remove the distributor too since it is driven by the cam through
    helical cut gears.
  22. Clevername
    Clevername
    If it is a flat lobe, replace the oil pump for sure -or at least make sure you got an oil pressure gauge...no, wait, replace the oil pump and get an oil pressure gauge:) I replaced a cam once, just to flatten another lobe -duh!
  23. thompsonwayne1
    thompsonwayne1
    I never did get around to putting oil in the cylinders and re testing compression. It would probably just be more bad news.I'll just drive it for the little bit of nice weather we have left and tear it down this winter. I'll probably just try to fix it as cheap as I can. It sure isn't a show car, more defintely a rat rod. Tranny is howling, brakes grab and pull like crazy
    You can put lipstick on a pig, but it's still a pig.
    Thanks to everybody here for all the help
  24. Well bad news or not you probably want to know. If compression comes up with oil then you know the seal at the rings is the issue and you'll be into some bottome end work. If it doesn't come up then you know its all top end & valve train/cam related.
  25. falcongeorge
    falcongeorge
    from BC
    Its a diagnostic tool. And its "traditional".
    In all honesty, I would go about 85% that it is a flat cam lobe. The point is, theres that 15% and checking for a pulled stud is REAL easy. On the other hand, I hadn't read the other thread, the compression readings have since come up here. The brutal fact is, this motor is a dead player and needs a rebuild.
  26. Im now concerned that you want to drive your car with brakes that ''Pull like crazy'' and I will pretend I didn't see the RR reference. JW
  27. Ebbsspeed
    Ebbsspeed
    Yeah, take it off the road now and fix the stuff. An engine that's down one cylinder won't hurt anything, but questionable brakes can kill you and others. You kill me because your car has faulty brakes, my wife will pull off your head and shit down your neck, AFTER she gets any money or assets you might have.
  28. CGkidd
    CGkidd
    Get it off the road and fix it correctly. Make it safe to drive...
  29. MAD 034
    MAD 034
    from Washington
    As said above fix the brakes. You always want to feel good about stopping before you feel good about going.
  30. DC43
    DC43
    Yes, fix the brakes fer cryin' out loud!!!!!!!!!!!!
    The very FIRST lesson my Grandpa and Dad taught me about hot rods, is as follows:
    Make it stop REALLY good first.
    Make it handle REALLY good second.
    Make it go just as fast as your wallet can stand to make it, LAST!
    (they were pretty smart guys, those two................)
